ive just replaced the maf so not good. think i will go back to car and check the serial number etc and check see if its the correct one. in the manual it doesnt tell u what the relays in the engine fuse box are for.
TBH I would consider going to a local breakers and trying one off the same car..maybe even a few if you get lucky. IF it/they dont work you'll at the least know its not the MAF and be able to get your money back.
02 sensors ?...
02 sensors both been replaced and have haas ones. i am going to check for wiring shorts. google again
hi the maf sensor is now a bosch 55350048 but nothing doing. check air filter and it wasnt dirty. cleaned sensor with contact cleaner and cleaner the plug also.
Did you scan the ecu for faults? I mean you just keep replacing parts but keep saying it isn't doing anything... but no codes are mentioned... if you don't have access to a reader, get one of those universal ones that will read only the engine codes.. at least than you'll know where to look.
okay update. checked fuses and relays all okay. maf sensor im unsure of readings. when motor running i unplug maf and nothing happens? read the codes and only 3 are recurring. P0100 P0135 P0141. ANY HELP be gratefully appreciated.... This was a few posts ago..I googled the codes and replied...
Truesay..
the only codes showing are the 3 i mentioned. p0100 p0135 and p0141. before this there was 8 codes and i remember p0443 which was evap or maf... now after everything just left with the above codes. when starting car it revs on its on over 2000rpm 4 times and then settles down.
as yet i have not replaced timing belt or water pump. but i have all the bits needed
