Thread: Code p1814 help
    May 2017
    Scarborough
    Vehicle : Vauxhall vectra
    Trim : elite/sri
    Engine : 3.2
    Year : Yj55
    Default Code p1814 help
    Hi everyone hope I've posted in the right place I'm still unsure on how to use site.
    Anyway I'm getting a warning light on dash, picture of car with spanner through it, when i do the pedal test I'm getting code p1814 ecc communication, I do intermittently loose heating controls and have to press auto button which then tells me residual heat activated or something then heaters are fine again. Altough sometimes it goes and I have to pull fuse and re insert.
    Car is a 2005 vectra elite 3.2 with electronic climate control, its an ex police car if that makes a difference. Oh also central locking doesn't work on passenger door not sure if that could be linked?
    Wondered if anyone else has had this problem and has managed to rectify it?
    Cheers in advance
    12 Post(s)
    You might want to use a proper fault code reader.
    A quick google says OBD fault code P1814 is "Transmission 4-Wheel Drive Mode Select Short Circuit To Battery"
    Says the same thing from the fault code list on here.
    VOTING UKIP IN AVELEY
    25 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    P1814 - Pressure Control Valve 1 (N215): Open/Short to Ground. Possible Causes. Wiring from/to Pressure Control Valve 1 (N215) Open/Short to Ground ...
    Another option on that code from google
    Regular Member koki's Avatar
    Aug 2018
    Macedonia
    Trim : Exclusive / Cosmo
    Engine : 2.8T
    I would also suggest a proper code reader. Either a standalone one or just a ordinary ELM327.
    Sent from my iPhone using Tapatalk
    May 2017
    Scarborough
    Trim : elite/sri
    Engine : 3.2
    Year : Yj55
    Fixed! Plugged into Vauxhall software thing on my laptop (as obd2 reader showed no codes), came up with p1814 no communication to ecc, for some reason my radio and screen were saying ECC=no so set it to yes and all is fine.
  1. 3.0 cdti code fault code
    By swfpt110 in forum Y & Z30DT Specific
    Last Post: 10th April 2016, 12:43
  2. Fault Code and Color Code help Please
    By smudger1767 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2014, 16:34
  3. fault code help code p1565
    By Hodgy in forum Engine & Drivetrain
    Last Post: 20th April 2013, 18:41
  4. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  5. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
