Likes Likes:  4
Results 1 to 10 of 13
Thread: Does this need under-sealing???
    Jul 2015
    Suffolk, UK
    Engine : 1.8 petrol
    Default Does this need under-sealing???
    2006 1.8 SRi
    I was a bit surprised to find my right-hand-side front subframe in this state:
    How far off an MoT fail do you reckon that is? It doesn't feel soft or anything but it's not good - a couple of years and that could be a fail, right?
    And replacing/repairing would be pretty expensive, I'd expect.
    Is it worth treating it somehow? My first thought was to get the angle-grinder on it with a wire brush attachment to remove the loose stuff and Hammerite. But I guess under-sealing would be the right way?
    Is it worth it though? I've never under-seled - is it a big job? Should I ask the garage to do it - I've heard it's a ****** of a job...
    Any thoughts much appreciated.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    38 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Use hammerite smooth satin black after you cleaned it up... because it will keep rusting until the it disintegrates.
    Ps apply rust converter to it after you cleaned it to stop it from going any further
    Jul 2015
    Suffolk, UK
    Engine : 1.8 petrol
    Quote Originally Posted by northpole View Post
    Cheers fella, sounds like a plan. Not too difficult fortunately as it looks like I can get at all the affected areas easily.
  4. Likes northpole liked this post
  5. #4
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    262 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Either way nothing will work now the rust is deep into the metal it will eventually go unless the rotten part is cut out. The rust will come back
    Teapot Tuned 245/300
  6. Likes northpole liked this post
  7. #5
    Apr 2016
    Ipswich
    38 Post(s)
    Mileage : 140000
    get a used one that is less crusty and take your time replacing it... Mine had some rust on it and rust converter with hammerite made it look like new.
  8. #6
    VIP-Member Jon1796's Avatar
    Sep 2015
    Norwich
    Vehicle : Vectra VXR
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 70,500
    Subframe loads on eBay. Easy with two people a right pain by yourself. Or take it off and powder coat it.
    Sent from my iPhone using Tapatalk
  9. #7
    Sep 2018
    Herts
    13 Post(s)
    Trim : Best
    Engine : 2.0T
    The 1.8's tend to rust more than the other models in the Vectra range, as they don't travel fast enough to shake off the rainwater.
  10. Likes roxburd, Big Dave liked this post
  11. #8
    Jul 2015
    Suffolk, UK
    Engine : 1.8 petrol
    Thanks guys - it hadn't occurred to me to replace it.
    I reckon some Hammerite will buy me some years as I think I've caught it fairly early.
    Hammerite claims to be a rust converter by itself... is it really worth using something else too?
  12. #9
    12 Post(s)
    You might want to add some cavity wax (eg waxoyl) to the inner part of it while you're at it. If it's not in a high impact area, rub off the worst of it and give it a generous coating of waxoyl. That stuff should penetrate far better than paint will.
  13. #10
    Jul 2015
    Suffolk, UK
    Engine : 1.8 petrol
    Woah there Big Dave, Waxoyl... I've heard of that... many years ago... isn't that like some mythical beast of old??
    { Googles }
    Ah no! Apparently, it's the big daddy of auto rust-treatments!!
    That sounds like a world of fun, squeezing under the car and covering myself in waterproof gunk.
    Sounds like the right thing, though, for sure.
    The website's not clear - the photo shows it in a can, like you pour it out and paint it on. But the text says "Available in Aerosol, Schutz, Refill Can & Pressure Can"
    WTF is a schutz?
    So anyway, do you recommend the regular aerosol? Doesn't sound like I'm gonna be able to get much inside the frame ("the inner part of it while you're at it") with a regular aerosol can though...
  1. EGR pipe sealing washer
    By greenhearts54 in forum Engine & Drivetrain
    Last Post: 3rd October 2015, 19:56
  2. sealing ring?
    By smartalec0310 in forum Engine & Drivetrain
    Last Post: 4th March 2013, 19:35
  3. egr valve sealing gasket 1.9 cdti 150
    By kev77 in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2010, 21:09
  4. Sealing headlights
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2010, 19:50
  5. Boot not sealing?!?
    By byebyeitsagsi in forum Bodywork & Interior
    Last Post: 22nd May 2009, 18:19
