Thread: Is it worth checking the valve clearances?
    Jul 2015
    Suffolk, UK
    Engine : 1.8 petrol
    Default Is it worth checking the valve clearances?
    The Haynes manual says the valve clearances should be checked at 100,000 miles. My local garage says 'Nah, don't bother'.
    The valves are currently a bit noisy for a few seconds after start - they'll be taking a little while to pressurise as the oil is old and so probably pretty thin.
    I'm hoping an oil change will sort that out.
    But I'm still thinking that it might be worth checking the clearances anyway. Loose valves will be noisy but tight ones won't and can cause valves to burn out. The fuel economy is still looking good though so maybe that suggests there's no need.
    Opinions?
    I do like a bit of maintenance and it's not a massive job, looking at the Haynes manual. The bit that I'm not so sure about is removing the wheel arch liner!
    12 Post(s)
    Aren't they hydraulic lifters?
    Thought they automatically adjusted themselves?
    If they're clattering on start up, then one or more could be worn and loosing pressure overnight.
    Jul 2015
    Suffolk, UK
    Engine : 1.8 petrol
    Yeah, they are hydraulic. They do automatically adjust, up to certain limits, I guess, if the valves are still working right.
    They are a bit noisy at start but I'm not bothered about that - an oil change will probably sort that out.
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 106000
    mine started being a big noisy on start up so did an engine flush and changed to 5w40 oil and noise has gone
    Mar 2017
    Hastings
    Trim : Exclusiv with Plus Pack
    Engine : 1.8i VVT
    Quote Originally Posted by roxburd View Post
    Unless it's the Z18XER engine which has solid lifters and should be checked every 100,000 miles. It's a shame Vauxhall chose not to use shims to set the valve clearance because it means replacing the lifters if it's not to spec at something like £12 a pop instead of a couple of quid a shim.
    I'm guessing they chose solid lifters because of the time it would take for the oil pressure to come up if it had to pump up hydraulic lifters as well as prime the cam phasers.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    38 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    cam lifter noise can be battled with an oil flush and clean oil of the right grade, in case of the 1.8 engines you are better of with 10w40 half synth. if that doesn't help than the only remedy will be the expensive route and replace them.
    Jul 2015
    Suffolk, UK
    Engine : 1.8 petrol
    Quote Originally Posted by simon194 View Post
    Thanks Simon - mine is the Z18XER with VVT... and yeah, you're right - it does have solid lifters.
    The engine was getting quite rattly at start. I've changed the oil (long story) and the rattle is completely gone.
    I guess as the rattle's gone none of them are hugely loose. And I guess they get looser as they wear, not tighter...
    Hmmm. Might be worth a check, though, I guess. It's done 109,000 miles now. Maybe I'll get a quote to have it done with the next MoT... and I won't like the quote so I'll do it myself... hmmm.
    Anyway, I had fun and games changing the oil - the drain plug head stripped out as I was trying to remove it. Yep. So that was fun with a chisel - really didn't want to slip and put a hole through the sump. Anyway, replacement plug was £6 from Jayar and from then on it was plain sailing - didn't drop a single drip of oil. In the past the wind has caught the draining oil and blown it all over the frigging place...
  1. Z19dt valve clearances advise needed
    By ianwat23 in forum Engine & Drivetrain
    Last Post: 6th September 2015, 01:26
  2. For Sale: few garage clearances. more will come
    By SlowCoach in forum Parts for sale
    Last Post: 20th November 2013, 15:13
  3. Z19DT valve clearances
    By C-Owner in forum Engine & Drivetrain
    Last Post: 15th August 2012, 11:57
  4. Checking Valve Clearances - 1.9CDTI (Z19DT - 120)
    By snapsnap in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd January 2012, 09:41
