Hi,
Does the Insignia have these warning lights like the Vectra C?
Many Thanks
Hi,
Many Thanks
Depends on what trim level you have.
Poverty spec probably hasn't.
Mid spec might have a code number flash up in the speedo display, which you have to cross reference in the handbook.
High spec should tell you which bulb is out in the speedo display. If it's anything like my Astra-J though, it's a bit vague in that it'll tell you that a brake light has blown, but not which one. Daft thing is, with the headlights and sidelights/DRLs it does identity left or right.
