Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Engine really struggling to run climate control
  1. #11
    Oxfordshire
    12 Post(s)
    Vehicle : Vauxhall Astra-J
    Engine : 2.0 CDTi
    Year : 2013
    Quote Originally Posted by Sindy View Post
    I'd try a new battery first, shouldn't be as low as 11.8 with the engine off. .
    Or get a load test carried out on it. Most places that sell batteries should have one and offer the service for free.
  2. #12
    Mar 2018
    Riga
    Vehicle : Opel
    Trim : Signum
    Engine : 2.8 V6 Turbo
    Thanks all. So I had it in at the dealers yesterday, they redid the wiring around the battery and replaced the battery, cost a small fortune. Apparently the wiring was all messed up and the battery around the connectors was all burned. But the worst part is it only solved the problem partly, now the engine behaves normally with high electrical load BUT, I still have problems with the outbox when the CC is on, basically when stopped in D, there's a horrible grind sound coming out of it, and the fuel consumption is up by about 10-15%.
    Everything is fine in P.
    I should probably repost this in another thread at this point.
  3. #13
    Mar 2018
    Riga
    Vehicle : Opel
    Trim : Signum
    You say theres a problem with climate control on, how do you turn it off? Mine has full ACC and its on all the time unless i manually switch the fan speed to 0 of course.
    That's exactly how I turn it of, by switching blower to 0. I've seen on YouTube somewhere the guy turning it off by pressing the middle dial, but that doesn't seem to work for me.
  4. #14
    Full Member
    Mar 2016
    North York
    Engine : 1.9
    If you can't push middle knob in it's need fixing. There is a how to on youtube - you will need soldering gun to do it. Try to press it really hard and cc menu should be visible.
    When you turn knob on 0 air compressor is still on, just fan is not working. That's mean engine still is using more fuel and power will drop a bit.
    I would say that air compressor is on it's last leg (seized - or getting there)
  5. #15
    Mar 2018
    Riga
    Vehicle : Opel
    Trim : Signum
    Quote Originally Posted by Lupus View Post
    Yeah, I can still get to the CC menu, by holding it down for bit. When I turn it to 0 though the fuel consumption goes way down, not sure if CC is still on or not.
    The compressor is probably on its way out though. I wonder if it could be causing problems with the outbox though. Although tbh, at this point I'm starting to get my fill of trying to fix this car, just for the next thing to give out.
  6. #16
    Oct 2013
    Derby
    264 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Letting those who try to help know which cabin air system you have would help, Lupus might be familiar with climate control i only know about the automatic climate control and the manual one so without picking up the hand book to find out how that third system works i wouldn't know. All i know is its something to do with AC so turn that off not the cabin air system.
    Teapot Tuned 245/300
    Tech2 & MDI diagnostics
  1. climate control to dual climate control question
    By dougie89 in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2014, 19:25
  2. another climate control
    By Даниил in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2011, 19:43
  3. Climate control Help
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2009, 00:23
  4. Climate Control
    By liphook in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2008, 04:10
  5. Climate Control
    By shark and mel in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2007, 18:33
