Results 1 to 10 of 16
Thread: Engine really struggling to run climate control
    Mar 2018
    Riga
    Vehicle : Opel
    Trim : Signum
    Engine : 2.8 V6 Turbo
    Default Engine really struggling to run climate control
    So here's a problem one in a long line since I've gotten 2.8 Signum last June.
    Basically whenever the climate control is on, regardless if its cold or hot air, the motor really starts to struggle.
    On idle the revs go up and become irregular, it starts shaking, etc.
    For some background, since last summer I've had the alternator restored, then the alternator pulley failed and was replaced. Then last month it was in at dealers, they found that the wire going to the LED daylights had not been properly fastened and was heating up which seams to have messed up the electrical elsewhere.
    The dealer thinks that as result of them daylights wire burning up, the wiring between the alternator and the battery needs replacing. Quoted me 1500 euro for new wiring
    Basically could it just be that the blower fan is done for and is pushing the alternator for more energy than it would normally need?
    The problem only seams to occur when the auto climate is on. Other electricals run fine even seat heating and cooling.
    Anyone seen something like that ?
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Have you had the charging voltage checked with the CC is on?
    Mar 2018
    Riga
    Vehicle : Opel
    Trim : Signum
    Quote Originally Posted by justin32 View Post
    Just checked, the voltage is perfectly within range abt 13.5 with engine on 11.8 when off.
    Also did tried to push the electricals to the limit without CC on, like had all seats heated etc. And that pushed the revs up a bit two, made the engine shake a bit.
    Mar 2018
    Riga
    Vehicle : Opel
    Trim : Signum
    Another thing, it really drives like crap with CC on, it might be just me, but with CC on it feels really heavy and sluggish.
    VIP-Member Jon1796's Avatar
    Sep 2015
    Norwich
    Vehicle : Vectra VXR
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 70,500
    What was V when everything was on.
    Sent from my iPhone using Tapatalk
    Mar 2018
    Riga
    Vehicle : Opel
    Trim : Signum
    Just the normal 13.5v, that's the strange thing, the alternator and battery seem to be fine
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    259 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    You say theres a problem with climate control on, how do you turn it off? Mine has full ACC and its on all the time unless i manually switch the fan speed to 0 of course.
    Teapot Tuned 245/300
    Sep 2015
    Norwich
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 70,500
    Going out on a limb here coil packs and plug gap. If gap is to big and coils are weak she gonna struggle.
    As your asking a lot of ‘V’.
    Sent from my iPad using Tapatalk
    Regular Member fatfred's Avatar
    Dec 2013
    Bristol
    15 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    Quote Originally Posted by tmf001 View Post
    I would expect around 14V charging.
    Post by @plasma here
    Regular Member Sindy's Avatar
    Dec 2015
    Yorks
    Trim : Mohican
    Engine : Z20NET
    I'd try a new battery first, shouldn't be as low as 11.8 with the engine off. See if you can borrow a known good battery off a mate before spending anything.
  1. climate control to dual climate control question
    By dougie89 in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2014, 19:25
  2. another climate control
    By Даниил in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2011, 19:43
  3. Climate control Help
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2009, 00:23
  4. Climate Control
    By liphook in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2008, 04:10
  5. Climate Control
    By shark and mel in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2007, 18:33
