Thanks Thanks:  1
Likes Likes:  3
Thread: Boooost
    Regular Member Eggy's Avatar
    Sep 2015
    Stoke on trent
    Trim : Vvt sri
    Engine : 1.8
    Year : 06
    Default Boooost
    What psi are people running in there 20 turbo z20net
    Sent from my iPhone using Tapatalk
    Ely, Cambridgeshire
    62 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Depends entirely on the turbo fitted as to what the map can be tweaked to. The early Z20NET's had the Garret 2052 low pressure turbo fitted which will crap its pants at over about 10 or 11psi (about 0.6 bar ish). The later ones had the TD0411T fitted as standard which will cope with a bit more.
    If you're thinking of running the stage 3 or higher map then you should look at the TD04L14T turbo. I was running 1.4 bar on mine (about 20psi ish) and it would hold 1.3 to 1.4 bar right the way through the gears.
  3. Thanks Eggy thanked for this post
    Likes Dog_Book liked this post
  4. #3
    Sep 2018
    Herts
    15 Post(s)
    Trim : Best
    Engine : 2.0T
    I would tell you how much boost my tuned Z20NET is running, but Ian H ^^^ fitted my boost gauge and now all it tells me is the time in Kazakhstan and the UV index for Western Australia.
  5. Likes Ian-Highlander liked this post
  6. #4
    Ely, Cambridgeshire
    62 Post(s)
    Year : 2010
    Quote Originally Posted by LastOne View Post
    Pah I dunno, you give the man bonus functionality at no charge and all he does is moan moan moan
  7. Likes LastOne liked this post
  8. #5
    Regular Member Sindy's Avatar
    Dec 2015
    Yorks
    Trim : Mohican
    Engine : Z20NET
    Was running the std Vaux map when I got it, 8psi ish.
    Had the std Saab map put on and now running around 15psi
  9. #6
    Sep 2015
    Stoke on trent
    Trim : Vvt sri
    Engine : 1.8
    Year : 06
    Quote Originally Posted by Ian-Highlander View Post
    Mines 07 plate if tha makes any difference. I can’t see what my turbo is either. People say look but for what I can see there’s no indication of make
  10. #7
    Ely, Cambridgeshire
    62 Post(s)
    Year : 2010
    Quote Originally Posted by Eggy View Post
    07 plate is "probably" the later TD0411T (although not guaranteed).
