Results 1 to 10 of 11
Thread: Vectra C 6 Speed Gearbox
    Mar 2007
    Attleborough, Norfolk
    Default Vectra C 6 Speed Gearbox
    Morning All
    I am generally happy with our recently acquired 55 plate 1.9 CDTi SXi but one thing I'm still not sure of is the 6 speed gearbox. I find the gear changing not to be quite as slick or quick as I expected with some changes into 2nd & 3rd not exactly graunchy but a bit "clicky" if you see what I mean. Rather the just push the stick through you feel as though you have to gently feel it into position. Does my description make sense?
    It may be me taking more time as I am getting older, to get used to new things but what do you other people with this gearbox think of the change?
    Thanks.
    Leicester
    Fine. I have had three now, the first car which was built in February 2004 (1.9 CDTi 150) had it's box changed at 49000 miles as it lost 3rd gear.
    But other than this, no problems, they can be a little notchy but this is the way it is built.
    [Ex]Admin Duncan's Avatar
    Other people have had problems with this box (F40) - several people have had them replaced so it's not uncommon. They can be a bit notchy, which is normal, but this can get worse where it then becomes difficult to select certain gears.
    Ian C had his replaced I'm sure, can't recall the others, but they should be able to give you their experiences of what it felt like etc.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I don't find 2nd - 3rd too bad but 1st - 2nd is very notchy - particularly when it's cold
    Regular Member LJ sxi-nav's Avatar
    Winchester
    I also have a 55 plate 1.9cdti sxi. The cars on 24000 miles, I've had it since 10000 and have had no problems with the 6 speed-box. Kind-of worrying to read that people have had them replaced tho!!!
    I'll look out for anything odd on the way home tonight, it might be one of those things you don't notice until its pointed out to you!
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    Vauxhall gearboxes have always been notchy. The addition of the 6th gear just needs you to give it a bit more of a wrench!!
    Regular Member Jim Bob's Avatar
    Widnes, Cheshire
    I find the gearbox on Astra's much better! Corsa's seems to have have a notchey box too!
    Full Member Big Sig's Avatar
    Mines the same but the dealer said it was fine??
    Regular Member fellie's Avatar
    Lincoln
    I have a somewhat low opinion of the change .. its about all I dont like on my vec-c ..
    and theres sod all you can do about it .. maybe lube the cable end connections, which is what I intend on doing..
    the 1st to 2nd in cold is well documented on here ..
    I have raised the question of an oil change, but its sealed, no carbon nastiness getting in the oil, and dealers state sealed for life .. ( although I still dont like the idea of oil doing such mileages lol )
    Oct 2006
    Wellingborough
    Yep, cold first to second is not good at all. second to third is ok, but simply ok. four five and six are all nice and smooth.
  1. 6 speed gearbox
    By billyyoung in forum Engine & Drivetrain
    Last Post: 16th September 2013, 07:54
  2. 5-speed gearbox on 6-speed z22yh
    By Ant SRi in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 09:06
  3. f28 6 speed gearbox and vectra b setup
    By neill in forum Parts for sale
    Last Post: 19th October 2010, 18:41
  4. Vectra 6 Speed Gearbox
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2009, 18:58
  5. 5 speed / 6 speed gearbox difference?
    By electron in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2007, 21:27
