Results 1 to 10 of 11
Thread: problem when pulling away at lights etc.
    Germany
    Default problem when pulling away at lights etc.
    Hopefully this is the right place for this
    I have a 2005 Signum 1.9 CDTI automatic no mods to engine
    When I pull away gently from stop I have no problems, but some times and only sometims when I pull away with some real power, after about three seconds the car pulls to the left, and I can even feel the streering wheel slightly turn ...anyone got any Idea what this could be ? is this a known fault ? Thanks for your ideas guys !!!!!!!!!!
    Regular Member Harry's Avatar
    Uxbridge, London
    torque steer?
    Jul 2006
    ^^^ What he said
    Germany
    Does anybody know what can be done to rectify it ? should it be covered by warranty ? Thanks !!!!!!!1
    Uxbridge, London
    it's not a fault - it's just the way the power is distributed to the front wheels, and the fact that it's done unevenly.
    it's a common 'characteristic' of front wheel drive cars, not sure if the fact that its an automatic amplifies the effect.
    have you mainly driven rear wheel cars in the past?
    Germany
    my last three cars were all vectra's older ones though never the 'C'. and this is the first automatic Ive had, so maybe that what is..plus the 150PS is more powerful than other cars Ive had ! thanks for your help mate
    Regular Member centaur's Avatar
    Coventry, West Midlands
    Good way to get rid of this problem is to go easy on the accelerator!
    A positive side effect of this is that you will save money on fuel too!
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Your delay is probably the time it takes for the turbo to kick in - Torque steer is common is FWD cars with drive shafts of unequal lengths. Under hard acceleration the car will veer towards the side with the longer shaft
    ....just like your missus will veer towards the longer shaft, too .........
    ok I'll get me coat.
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    You should try getting the power down in a 275BHP FWD Volvo T5!
    Now thats torque steer!!!!!!!!!!!!
    In the wet, its best just to park up!
  1. Problem with 1.8 VVT and jerky pulling away
    By Ash103291 in forum Engine & Drivetrain
    Last Post: 31st January 2013, 14:54
  2. Braking Lights problem?
    By misterpants in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2012, 14:01
  3. Problem with my lights
    By kman247 in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2011, 10:10
  4. lights problem
    By coooky in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2011, 15:36
  5. Lights problem - lights out
    By DarkNite in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2007, 16:30
