Likes Likes:  1
Thread: Lack of Power Below 2k Vectra C CDTI
    New Member alan p's Avatar
    Mar 2017
    Wiltshire
    Trim : SRI
    Engine : 1.9 CDTI
    Mileage : 138247
    Question Lack of Power Below 2k Vectra C CDTI
    I have an problem with my Vectra, when i first start i get the spanner light which goes out after a few minutes but i have very little power untill the revs get up to around 3,000 then it takes off like a train, when the car gets hot which can take awhile the spanner light comes on and i have no power above 3,000 but the bottom end response is better, if i turn the car off and on again the spanner light goes out but the check engine light comes on and the car runs better ie better bottom end with power above 3,000. I have cleaned the EGR added the Fiat gasket, changed the boost sensor put a fuel cleaner through the tank and checked the vac pipes the manifold flaps seam to be working and the rod is in place any ideas as im running out of options
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    24 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Have you thought of checking the car for any fault codes?
    Mar 2017
    Wiltshire
    Trim : SRI
    Engine : 1.9 CDTI
    Mileage : 138247
    I have and there is nothing logged !!
    Mar 2013
    Scotland, North East
    Vehicle : Saab 9-3 (Vectra C in disguise)
    Trim : Linear Sport
    Engine : 1.9 TiD 150
    boost sensor aka MAP or boost solenoid?
    Spray some soapy water on the flaps, see if you get any bubbles
    Do you get any screeching / squealing noises?
    Mar 2017
    Wiltshire
    Trim : SRI
    Engine : 1.9 CDTI
    Mileage : 138247
    changed the boost sensor in the manifold not the solenoid which is on the front panel I belive, flaps seem to be moving and the problem has come on suddenly not a gradual change, not heard any squealing or screeching.
  6. Likes llamallama liked this post
  7. #6
    Regular Member llamallama's Avatar
    Oct 2015
    Australia
    Vehicle : Vectra ZC
    Trim : CDXi
    Engine : 3.2L V6 Z32SE
    Mileage : 236754
    Suddenly,
    Maybe check the intercooler hoses and vac lines
  8. #7
    Oct 2015
    Australia
    Vehicle : Vectra ZC
    Trim : CDXi
    Mileage : 236754
    This video might shed some insight,
    https://www.youtube.com/watch?v=o1Hvt2b7PL0
  9. #8
    Oct 2015
    Australia
    Vehicle : Vectra ZC
    Trim : CDXi
    Mileage : 236754
    Yep just read, you checked the pipes
    My bad
  10. #9
    Mar 2017
    Wiltshire
    Trim : SRI
    Engine : 1.9 CDTI
    Mileage : 138247
    Im thinking Maf or replace the egr although i cleaned it out it might not be sealing correctly
  11. #10
    Gloucester
    check the throttle body?
    had very similar symptoms, took throttle body off inet manifold almost completely blocked!!
    run fine again now
  1. Vectra C 1.9 CDTi 150 lack of power
    By BenLothian in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2019, 09:11
  2. Vectra cdti 150 smoking and lack power below 2k revs
    By Jay_61279uk in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd November 2018, 21:26
  3. Vectra C 150 CDTi Lack of Power
    By sclarkson82 in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2011, 21:07
  4. Lack Of Power (2004 1.9 cdti 8V)
    By user999998 in forum Engine & Drivetrain
    Last Post: 2nd June 2009, 09:03
  5. cdti 150 lack of power
    By michael cummings in forum Diesel Engine related
    Last Post: 8th February 2009, 20:44
