hi just fail mot on hand brake what I need to adjust in here ? please thank you
It’s auto adjust....
Sent from my iPad using Tapatalk
hand brake fail...as in not holding?..BUT rear brakes are ok?..
could be the spring cause a problem to the hand brake mechanism not to adjusting
my spring not bring back the cable and stay like this
it should go back al the way like this
I think the spring is not strong enough
Try this
hand brake off, push holders on calipers (both) so handbrake cable extends, pull handbrake on and off with button depressed 3 or 4 times
Check handbrake is locking wheels evenly
hi thanks I will try this I ordered sorter springs hope that help will update when finish
What exactly did it fail on? i.e. what was written on the fail sheet?
parking brake efficiency below requirements
could just be cheap disc or pads or both.
I had this issue with ECP's cheapest pads and discs
