Likes Likes:  5
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: whole turbo or just the cartridge?
  1. #11
    Apr 2016
    Ipswich
    34 Post(s)
    Vehicle : Vectra C
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    Quote Originally Posted by LastOne View Post
    If you buy a replacement cartridge you'd then have to pay to have it balanced, surely?
    The cartridges are balanced you need to have the actuator set properly.. although some places sell unbalanced cartridges.. avoid those
  2. #12
    Mar 2013
    Scotland, North East
    Vehicle : Saab 9-3 (Vectra C in disguise)
    Trim : Linear Sport
    Engine : 1.9 TiD 150
    I got the mrs to stand at the front of the car when I revved it and she reckons there's a definite shriek coming from the boost solenoid and its buzzing on shutdown also (which I'm sure I read somewhere is a sign that its on the way out)
    So something else to swap out
  3. #13
    Oct 2013
    Derby
    255 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by MrF View Post
    Should be silent, at least it always was on mine
    Teapot Tuned 245/300
  4. #14
    Mar 2013
    Trim : Linear Sport
    Thats what I thought like, only started this after it was stood for 5 months. Wonder if you can strip them and free them off or whether there's a diaphragm inside thats perished.....
  5. #15
    Oct 2013
    Derby
    255 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Nope
  6. #16
    Apr 2016
    Ipswich
    34 Post(s)
    Vehicle : Vectra C
    Year : 2003
    Mileage : 140000
    replace it, than take the broken one apart... you'll soon see why it's a non serviceable item
  7. #17
    Regular Member matthewp1633's Avatar
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Trim : 150bhp
    Engine : 19dth Teapot tuned
    Year : 2008
    Mileage : too many
    Cartridges are ok as long as you get a good make and the actuator is adjustable but leave it as it is and unclip it. That is what I did on my daughters astra as long as it isn t miles out I believe the ECU will still control boost pressures but others may know better. I just know as long as you are careful to unclip the actuator and fit the cartridge in the position it came off them refit the actuator clip its fine.
    Good one are balanced already and are about £150
  8. #18
    Regular Member Teapot's Avatar
    Mar 2010
    woodbridge, suffolk
    246 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    The screeching noise is usually caused by a leak at the exhaust manifold gasket, or a crack in the exhaust manifold. This would also cause excess turbo lag. Sometimes one or two of the exhaust manifold studs snap off or come loose. This is relatively easy to check in situ once you get the heatshield off.
  9. #19
    VIP-Member Samyam's Avatar
    Jan 2018
    Coventry
    5 Post(s)
    Vehicle : Vauxhall astra
    Trim : Sxi
    Engine : 1.6
    Quote Originally Posted by Teapot View Post
    This is what has happened to mine but I didnít feel any loss in power
  10. Likes northpole liked this post
  11. #20
    Mar 2013
    Trim : Linear Sport
    I've had that screech before. Mine is a different type and it's coming from the solenoid rather than the turbo hard to explain really
    Sent from my SM-G930F using Tapatalk
  12. Likes northpole liked this post
  1. Oil Feed Pipe - Turbo Cartridge
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2016, 15:48
  2. Replace turbo charger or just the cartridge??
    By Desolation91 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2014, 08:00
  3. fitted new chra turbo cartridge but not the same
    By djkallem in forum Engine & Drivetrain
    Last Post: 30th May 2014, 22:38
  4. Turbo cartridge replacement
    By Swedge in forum Engine & Drivetrain
    Last Post: 25th March 2013, 19:24
  5. Multi CD cartridge
    By The-Bandit in forum Parts for sale
    Last Post: 4th May 2008, 21:30
