My car is on 160,0000 miles and ive noticed over the years its loosing its poke even though its got:
Teapot map
FMIC
EGR blanked from turbo end
Swirl bar mapped open and EGR removed
Back box delete
Race tube
Fairly recent Clutch and flywheel
New manifold
Theres nothing wrong with it and ive always kept up on things like cleaning throttle body, boost sensor, regular oil changes, Vacuum hoses replaced (GM ones). There are no strange noises or anything and injector readings are pretty good so my only other thought could be turbo. The turbo has always whistled from the day I brought the car about 7 years ago and when I had my clutch and flywheel replaced (by a member on here) he did mention that there was a screeching noise at high revs and also slight play in the shaft. The screeching noise I can remember but it disappeared.
A friend of mine brought a Vectra last week that is pretty high mileage (almost 200k) and is standard with no mods at all.I drove it and was expecting it to be no match for mine but I was really shocked at how fast it was. The turbo spooled up quickly and when it kicked in it lifted the front of the car and had to grip the steering wheel due to the torque steer, it also revved a lot quicker and had better throttle response which I havn't had that from my car for years and years!
Now its got me thinking that could my turbo just be a bit tired now and need replacing? I remember watching an episode of wheeler dealers and I forget which car they brought but Edd ended up replacing the turbo as it just felt a bit sluggish and under powered which in truth is what mine feels like.
Ive looked into replacement turbo but also came across a replacement cartridge for the turbo which is half the price but not sure if its worth the hassle of stripping it down and I read that it is a delicate job and can be a bit fiddly
What do you guys reckon?
