my son has fitted his coil overs today but he's not overly happy with the result.the standard of quality and ease of fit was ok even tho they are cheapies and the ride quality is very good over the set up he had before but the description states a 35-75 mm drop well he has wound them down to the lowest setting and it doesn't look much lower than the 35 mm drop he had before, he understands they will settle a bit over the next few days and he doesn't want to slam it to the ground either and while it is quite low he was hoping to go a little lower than before.he is aware you get what you pay for and plenty of you will suggest better quality and more expensive ones but the reviews for these were quite good and it is his first car and apart from what he thinks it ain't worth a lot.has he done something wrong because if these were wound up even half way the car would look like a off roader. he assembled them on the bench with the adjuster at its lowest point.
