Results 1 to 7 of 7
Thread: Jolt - when easing off the accelerator
    Nov 2007
    Telford
    Default Jolt - when easing off the accelerator
    Hi guys,
    When I'm easing off the accelerator - even very very gently - there seems to be a slight 'jolt' coming through the car.
    Before the easing off has been very smooth and damped.
    It only seems to have developed over the last 3-4 months - any ideas what it might be ?
    Vectra SRi XP '56 plate - 2.0 Petrol Turbo ( 155,000 miles )
    Dec 2014
    I'm experiencing something similar. Like a jolting, hard down-shift when I ease up on the accelerator or step on the brake. Very harsh, you feel it on your feet and around.
    Regular Member Entharion's Avatar
    Nov 2018
    Netherlands
    Vehicle : Opel Vectra
    Trim : GTS
    Engine : 2.0 Turbo (Z20NET)
    I've experienced this I think, can you feel it through the gearstick as well?
    The mounts on the gearbox and rear have already been replaced with no noticable difference.
    But I also have a slight rattle on low-rpm high-load acceleration, so I'm suspecting the DMF, driveshafts or gearbox could be at fault in my case.
    Dec 2014
    Quote Originally Posted by Entharion View Post
    Yeah, yours sounds a bit different. Mine was a harsh gear shift, downward. I was told it's the gearbox, which I changed, but still experiencing the same. Now they say it's the vehicle speed sensor. Don't know what to believe anymore.
    Apr 2016
    Ipswich
    47 Post(s)
    Vehicle : Vectra C
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    The vehicle speed sensor is cheaper than the next more obvious cause... your DMF is probably past it's best and is running out of balance. especially if you check your engine mounts and gearbox mounts and all are in good condition.. drive-shafts will be fine unless you have a split in the boots and they actually lost all grease... but you'd already have noticed that because every time you'd turn into a corner you'd hear clicking.. . plus you'd find black grease all over the firewall, wheels, engine etc..
    Nov 2018
    Netherlands
    Trim : GTS
    I'm afraid it's going to be a new DMF for me. But at least the shafts should be fine, they don't make noise when turning and all the boots are OK.
    Quote Originally Posted by Inas View Post
    Sounds more like engine/gearbox mounts to me, as the wheels slow down the engine slows down through the gearbox, it could be tilting your engine back and forth rather harshly.
    Dec 2014
    Will check the mounts then.
  1. Accelerator
    By Dannyclarke in forum Electrical & ICE (including SatNav)
    Last Post: 17th June 2017, 23:41
  2. Weird jolt while driving
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2012, 16:27
  3. strange jolt or misfire ??
    By stuthevaux in forum Engine & Drivetrain
    Last Post: 7th August 2012, 00:07
  4. Black thick ATF and Jolt when engaging drive on Auto Box
    By mditzel in forum Engine & Drivetrain
    Last Post: 14th September 2011, 22:27
  5. Jolt when step down from second gear to first - Automatic, Vectra 2003
    By cluckens in forum Vectra C / Signum Troubleshooting
    Last Post: 27th February 2010, 16:09
