17th March 2019, 20:27
#1
Jom coil overs adjustment
Installed rear coilovers on the vectra cdti, currently they are adjusted close to the top and car is very low tyre slightly in the arch, wheels are 19 inch snowflakes,
if I adjust the mount anticlockwise so the platform now sits lower will the car raise or lower
the fronts have not been fitted at the moment
17th March 2019, 20:34
#2
Originally Posted by
turbo diesel
any pics??
17th March 2019, 20:48
#3
havent any pics thy were installed on friday i hope thats no tthe highest setting as my tyre is in the arch, I don't know if the fronts not being in make any difference
17th March 2019, 22:05
#4
I have joms and the same issue. They do sit lower at the rear which is a pain as they are quite soft too so any weight at the back causes it to sit really low and scrape over bumps. Ive got some rear SRI spring from my original set up so will fit them and just raise the fronts up
17th March 2019, 22:06
#5
turbo diesel
The more you twist the collar downwards, the higher the ride height.
17th March 2019, 22:15
#6
even on the highest setting it sits low
17th March 2019, 22:58
#7
my platforms have been turned clockwise so sitting at the top, any futher and the platform will screw off from the top
so if I turn this anticlockwise then the platform goes down and the car will raise, is this correct
17th March 2019, 23:23
#8
turbo diesel
Yes, because you'll be lengthening the spring. Longer springs = higher ride height.
17th March 2019, 23:30
#9
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
18th March 2019, 00:06
#10
don't have it set too high because my springs jumped off a couple of times
