Likes Likes:  1
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 1.8 Z18xe dumping coolant
  1. #11
    Mar 2019
    Wallasey
    Vehicle : Vectra C 1.8
    Trim : Club
    Engine : 1.8
    Heaters work fine.
    Coolant fan doesn't even get the chance to kick in before it eats it's coolant.
    All hoses/clips on front and side of engine are fine unsure if there are any behind at this point.
    Thermostat has been changed and still no joy at this point
  2. #12
    Nov 2007
    DERBY
    22 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    OK..Are you topping up the coolant?...Id be inclined to drain the systen down and measure what you have in...then start again with clean fluids.
    Is the drain point on the radiator ok?..
  3. #13
    Nov 2013
    suffolk
    Vehicle : vectra 2007
    Trim : sri
    Engine : z18xer
    Where is the coolant coming from? Not a Core plug by any chance?
  1. topping up coolant after header tank change z18xe
    By superpasty in forum Engine & Drivetrain
    Last Post: 14th April 2018, 15:44
  2. For Sale: Coolant bleed screw, genuine for front coolant pipe most engines
    By Dog_Book in forum Parts for sale
    Last Post: 20th April 2017, 19:01
  3. Coolant Temp 1.8 LS Engine Code Z18XE
    By ads77 in forum Engine & Drivetrain
    Last Post: 29th January 2016, 11:02
  4. Z18XE coolant pressure question
    By SteveSxi in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2014, 18:01
  5. Dumping noise from turbo during gear change
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2009, 16:34
