Thread: Vectra C 150. Will not start
    Dec 2010
    York
    Default Vectra C 150. Will not start
    Well it’s been a strange few days.
    key fob stopped working and wouldn’t unlock the car. Unlocked with key and put key in ignition this turned off the alarm. But when I tried to start the car it wouldn’t even turn over.
    The keys started working OK and I was able to lock and unlock the car but still will not start it.
    Noticed that when I remove the key from the ignition and opened the door the car was beeping like the lights were on or the keys were in the ignition.
    If i short out the starter motor the car runs and drives and seems fine.
    I have removed ignition barrel and cleaned.
    Ive found it hard to find people with the exact same issues any help would be great
    Apr 2008
    West Yorkshire
    Try your spare key in case your transponder is having issues. I'll assume you've already tried synchronising your key to the car as per the handbook
    Dec 2010
    York
    Tried with both keys have exactly the same issue, tried to resync but still won’t turn over.
    I am able to use the car I have had to run cable direct to starter motor, I put the normal key in the ignition then use the direct cable to the starter motor to start the car.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    I actually think your ignition is past it's best since the keys re-registered properly otherwise the car wouldn't start period... maybe you can get another ignition barrel that is set for your keys profile but i have no idea what that would cost.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    25 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    how 'easy' is it to replace the locks etc with a known working 2nd hand one?..
    13 Post(s)
    Quote Originally Posted by NickT View Post
    This procedure is for only operation of the remote central locking and alarm.
    The immobiliser is dealt with by a transponder chip that communicates to/from the car via wireless induction. The fob battery can be completely flat and you should still be able to start the car.
    Dec 2010
    York
    I have wondered if something on the barrel may have worn down and is no longer making the proper contacts. I might look at replacing the barrel I hopefully might be able to get the barrel PIN numbers from my current barrel.
    Regular Member wildchild's Avatar
    Sep 2011
    Wolverhampton
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 174000
    Hi m8 my cousins astra suffered from something like this and we took the ignition barrel out and the is a plastic plunger in the end, i stripped it down and sprayed it all with electrical cleaner and it was quite gunked up as it should be free moving... and that seemed to work but i also at the same time found a fault code in the cim module so i cleared it with opcom and its been ok ever since hth
  1. Replies: 11
    Last Post: 5th June 2020, 21:48
  2. Vectra won't start
    By phillipsmw in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd December 2013, 09:47
  3. my vectra will not start
    By faizyan6000 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2013, 08:32
  4. Please HELP - Car Won't Start (Vectra C)
    By d-suhiti91 in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2010, 09:12
  5. Vectra 2.0 cdx won’t start?
    By PapaTgash in forum Vectra C / Signum Troubleshooting
    Last Post: 4th December 2007, 09:06
