Results 1 to 2 of 2
Thread: Pulling down the rear backrest problem
    Feb 2019
    Budapest
    Trim : used
    Engine : 1.8
    confused Pulling down the rear backrest problem
    Hi!
    I have a 2004 1.8 Sedan Vectra C. The left rear seat backrest pull down mechanism has been ruined, the lever is not working and the backrest cannot be tilted forward. How do I access the lock mechanism without removing the seats? If it can be at all. If it can only be solved with removing the seat, can the backrest be removed at all? Will the shutter release it?
    If you have any ideas or somebody has installation instructions with pictures, I'd appreciate it.
    Gábor
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    You'll have to prise it off with a screw driver as the hook that clamps it in just has to be moved up... it is on the side of the wadding right on the top... look at the other one first so you have an idea how far it is located behind the wadding...
    It will be the only way to get it free... once out is free you can repair it when you take the handle apart. Or just get another back rest of a scrapped car.
  1. Problem with 1.8 VVT and jerky pulling away
    By Ash103291 in forum Engine & Drivetrain
    Last Post: 31st January 2013, 14:54
  2. rear middle seatbelt not pulling out
    By callum in forum Bodywork & Interior
    Last Post: 5th December 2011, 12:14
  3. problem when pulling away at lights etc.
    By chrish in forum Suspension, Wheels & Brakes
    Last Post: 8th May 2007, 14:40
  4. Replies: 0
    Last Post: 25th June 2005, 16:11
  5. FR 1514: Backrest hinge of rear seat - Rattling noise (Vec C)
    By Duncan in forum Body & Body Equipment
    Last Post: 25th June 2005, 16:08
