Thanks Thanks:  2
Likes Likes:  3
Results 1 to 10 of 10
Thread: New Matrix or K-Seal?
    Mar 2011
    berkshire
    Vehicle : Vauxhall vectra 1.9cdti 8v 120bhp
    Trim : Breeze
    Engine : 1.9cdti
    Mileage : 166,000
    Default New Matrix or K-Seal?
    Lost about a cup of coolant within 1 week and found passenger footwell wet. Everything is pointing to heater matrix.
    Car is vectra c 1.9 120 8v 05 plate so don't really want to spend too much due to time consuming job.
    I was browsing around and came across K-Seal and was wondering if it's worth trying it.
    Someone said they were topping up 2ltrs in coolant due to loss and k-seal fixed it. So going by that assumption I only lose 1 or 2 cup full's in a week.
    The footwell is mainly wet to the left of the car and slightly mid.
    What do you guys think?
    Oct 2014
    I did use it on my vectra c - radiator leaks. And i have to say that k-seal did the job.
    But I would recommend you to use it as it says on the bottle and flush the coolant after 1 day and pour new coolant in there.
  3. Thanks Samyam thanked for this post
  4. #3
    Apr 2016
    Ipswich
    93 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    Replace it... k-seal will do the job of sealing it if it is a small leak...but for me that stuff is like an emergency repair... only good to help you to bridge the time to solve the problem at a more convenient time.
  5. #4
    Sep 2018
    Herts
    17 Post(s)
    Trim : Best
    Engine : 2.0T
    Year : 2008
    I had a leaking matrix, not enough to notice a drop in the water level, but when using the heater fan the cabin would fill with the sickly sweet smell of coolant. One bottle of K-seal mostly fixed the problem, with the smell occasionally returning. A second bottle a few weeks later fixed it for good. That was 2.5 years ago. IIRC it says on the bottle that it's up to you whether you change the coolant after using the K-seal or leave it in there indefinitely.
  6. #5
    Oct 2014
    I preferred to change the coolant as leaving k-seal in there for longer may cause more problems. That's what I think.
  7. #6
    Sep 2018
    Herts
    17 Post(s)
    Trim : Best
    Engine : 2.0T
    Year : 2008
    I think that's called guessing.
  8. #7
    Regular Member fatfred's Avatar
    Dec 2013
    Bristol
    15 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    Only ever used it once. Rover 45 head gasket fubared. Spent £700+ having the gasket done only for it to go 18 months later. 1 bottle and an auction later, Rover gone...... not sure you're interested but you've read it now!
  9. Likes RBH liked this post
  10. #8
    Regular Member matthewp1633's Avatar
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Trim : 280 bhp-550Nm
    Engine : 19dth Teapot tuned
    Year : 2008
    Mileage : too many
    Be aware that water on the floor doesn t always indicate a heater matrix because the scuttle panel drains often block and rain gets in hence the wetness. Use your finger to taste the water on the footwell and if it is sickly sweet and tastes horrid its anti freeze!
    If no horrid taste clear the scuttle channels and look elsewhere for your coolant leak.
    Be careful not to taste too much as anti freeze is poisonous in large amounts!
  11. Likes JPVectraC, jingerman liked this post
  12. #9
    Mar 2011
    berkshire
    Trim : Breeze
    Engine : 1.9cdti
    Mileage : 166,000
    Put a bottle in 236ml, ran to 90c, fan kicked in, left heaters on full blast and drove it for 30 minutes, lets see.
    I top up coolant to Kalt sign and after a week it loses about 200ml.
    Hopefully with k-seal it might stay there.
    Was wondering if it was something to do with my open thermostat issues?
  13. #10
    Dec 2013
    Bristol
    15 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    If there are no leaks the coolant level will stay the same. It won't matter if the stat is open or closed, it should be a sealed system.
  14. Thanks jingerman thanked for this post
  1. Heater matrix
    By hardin in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2013, 08:48
  2. heater matrix
    By strothrc in forum Engine & Drivetrain
    Last Post: 13th March 2012, 13:31
  3. 2.0T oil leak, poss crank seal or sump seal?
    By mann3210 in forum Engine & Drivetrain
    Last Post: 3rd March 2012, 11:11
  4. Heater matrix!
    By SUBEK in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd December 2011, 15:43
  5. A rift in the matrix
    By Jamie in forum Comedy & Humour
    Last Post: 15th August 2005, 09:03
