12th February 2019, 12:02
#1
The Darklord ponders his rear suspension
Well, emboldened by the recent work work on the front suspension (even if the springs are the wrong ones -sigh), the Darklord has been pondering why the rear suspension is so firm, as witnessed by the struggle to install the new rear springs.
Since the rear suspension wouldn't drop down easily, the pivot points must be sized in some way.
Is it possible to overhaul the required bearings/bushings, or does everything come as complete unit, is, complete suspension arms?
Or are there area I could try forcing lubricant in?
The ride from the rear is rather firm, slightly improved with the new springs, but still rather solid.
Your musings gratefully received.
12th February 2019, 13:33
#2
You’ll probably be replacing arm and bolts, if there that rusted in.
You can replace bushes or put poly’s in but probably cheaper to just replace arm.
You might if you’ve lucky/got enough room which there isn’t much undo nut spray with lube both ends and try knocking bolt in and out to free off, if you’re lucky.
Sent from my iPhone using Tapatalk
12th February 2019, 15:55
#3
Don't use any poly bushes as they make the ride even firmer.
12th February 2019, 16:09
#4
If it’s a problem then I would ponder for information in the technical section like the title of this section advises
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
RBH liked this post
12th February 2019, 21:32
#5
Originally Posted by
LastOne
But should be better keeping the rust at bay with there collars. Hopefully.
12th February 2019, 21:42
#6
LastOne
One Ive used in select locations have been fine and i gained better handling as i didn't want a firmer ride.
13th February 2019, 00:56
#7
I replaced the entire lot on my Vectra with black series poly bushes , B8 shocks and custom made springs ride was fantastic was on rails and also full hunter set up of front and rear geometry
