Likes Likes:  2
Thread: What is this part called
    Jul 2009
    varna
    Engine : z22se
    Mileage : 40k
    Default What is this part called
    Hello mates,
    I am having the same paint chips problem as in this video and I am considering whether to repaint it or replace it with another one:
    https://youtu.be/vPCXQh16ZLE?t=5
    Could someone tell me what is this part called, or it's number for a Vec C sedan.
    Kind regards,
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    38 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Quote Originally Posted by bambal View Post
    Hello mates,
    Kind regards,
    Just paint it..... all you need is automotive acrylic satin black paint, some masking tape and a bunch of newspapers... as per the video make sure you cover all the bits with the masking tape and news papers..
    Sand it down so it nice and smooth...
    Than spray 3 layers and wait for 10 minutes between each layer so it can dry a bit in between and that gives the best result.... also removing that part is quite time consuming, so that is the cheapest, quickest and most used way.
    Alternatively you could wrap it with vynil in the same colour or whatever you fancy..
    Wrapping does give you a whole array of different looks so it is up to you what you go for.
    Jul 2009
    varna
    Engine : z22se
    Mileage : 40k
    Thank you for your reply!
    I am hesitating about painting it because I am not sure how to remove it, I have searched for manuals about it but could not find any. You said it is a time consuming job, why is that?
    Administrator plasma's Avatar
    On the Forum
    504 Post(s)
    Engine : 150
    Mileage : 74000
    i'm reckoning at a wild stab in the dark here, that because of the amount of prep work and doing it would consume a lot of time to do properly
  5. Likes northpole liked this post
  6. #5
    Sep 2018
    Herts
    13 Post(s)
    Trim : Best
    Engine : 2.0T
    I had the same problem on the same part on my Signum. The solution was to remove it, lightly sand it and then wrap it with sticky vinyl.
  7. Likes northpole liked this post
  8. #6
    Apr 2016
    Ipswich
    38 Post(s)
    Mileage : 140000
    Quote Originally Posted by plasma View Post
    I was actually saying that removing it takes way to much time.... mask it up properly and after that it'll be painted within half an hour...
  1. What is this Part called?
    By mm2809 in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2015, 21:10
  2. Another whats this part called?
    By justin32 in forum Engine & Drivetrain
    Last Post: 1st April 2013, 21:23
  3. Whats this part called please?
    Last Post: 1st April 2013, 18:45
  4. Anyone know what this part is called...
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2009, 22:35
