Thread: Check Safeguard
    Feb 2019
    Eastleigh
    Vehicle : Vectra 2.2 cdi ellite
    Trim : Ellite
    Engine : 2.2
    Default Check Safeguard
    Hi there, Iím new on here, Iíve just got myself a really clean 2003 Vectra 2.2 diesel, itís my first vectra, but Iíve found some issues, the heating didnít work, which I found to be the heater resistor under the passenger side, so I have replaced that, I have no interior lights, Iíve checked the wires in the light fixing by the safeguard sensor but all seems ok, Iíve pulled every fuse out & checked and they too are all ok, I have also found out that the rear heated window isnít working, Iíve searched on line, but not really come up with the correct answer can some one please help, itís driving me mad.
    Sent from my iPhone using Tapatalk
    VIP-Member Jon1796's Avatar
    Sep 2015
    Norwich
    Vehicle : Vectra VXR
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 70,500
    Could be the ribbon from rear rec is dead if youíre checked all the fuses.
    Sent from my iPad using Tapatalk
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    255 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Best place to look is the troubleshooting section then
    Teapot Tuned 245/300
    12 Post(s)
    Regarding the blower resistor. Did you check the blower motor spins freely? If not, then it could well fail again.
    Easily accessed by taking the pollen filter out and spinning it by hand.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 153000
    Quote Originally Posted by Oilslickwillie View Post
    Hi there, I’m new on here, I’ve just got myself a really clean 2003 Vectra 2.2 diesel, it’s my first vectra, but I’ve found some issues, the heating didn’t work, which I found to be the heater resistor under the passenger side, so I have replaced that, I have no interior lights, I’ve checked the wires in the light fixing by the safeguard sensor but all seems ok, I’ve pulled every fuse out & checked and they too are all ok, I have also found out that the rear heated window isn’t working, I’ve searched on line, but not really come up with the correct answer can some one please help, it’s driving me mad.
    is your car an estate ?
  1. Safeguard check
    By andyrfc in forum Electrical & ICE (including SatNav)
    Last Post: 1st November 2018, 22:34
  2. Safeguard check
    By VikingLammy in forum Electrical & ICE (including SatNav)
    Last Post: 17th December 2012, 21:39
  3. check safeguard ?????
    By tolly in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2012, 10:59
  4. Check Safeguard (Again)
    By stevem in forum Vectra C / Signum Troubleshooting
    Last Post: 6th August 2008, 19:31
  5. safeguard check
    By marts cdti in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2008, 13:41
