Thanks Thanks:  1
Thread: insignia reversing lights
    Mar 2011
    wilts
    Vehicle : insignia nav design cdti
    Trim : half leather
    Engine : 2.0 diesel
    Year : 2015
    Mileage : 63675
    Default insignia reversing lights
    my insignia has useless reversing lights , as I drive mostly when lights needed I cant see much when reversing. small little lenses, would led bulbs help? its a 2014 car ive tried pulling right unit out but dont want to force it.
    Sep 2018
    Herts
    17 Post(s)
    Trim : Best
    Engine : 2.0T
    The primary function of reversing lights is to warn others of your direction of travel, rather than to illuminate the way - hence why some cars get away with only having one reversing light, with a foglight taking the same place on the opposite side of the car.
    Mar 2011
    wilts
    Trim : half leather
    Engine : 2.0 diesel
    Year : 2015
    Mileage : 63675
    the way I look at it, is having had extensive neck surgery I cant turn neck to see behind so use mirrors, when reversing out of a parking space across our works car park its not possible to see whats behind so use mirrors instead. no lights on car park and slight incline to reverse out of. my old vectra and other cars before never had problems. maybe you suggest I use fog lights instead..
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    I’ve done that sometimes when there’s not enough light, when I had a van for racing I fitted a work light under the rear bumper connected to the reverse lights that worked amazingly
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Jan 2008
    117 Post(s)
    Vehicle : .....
    Trim : .....
    Engine : .....
    Year : .....
    Mileage : .......
    Quote Originally Posted by chaz851 View Post
    The answer to your LED question is no.
    I've tried them in mine and although they're brighter inside the lens, they do not illuminate the way when reversing.
    I've switched back to standard filament bulbs as they give more output.
  6. Thanks chaz851 thanked for this post
  7. #6
    Jan 2008
    117 Post(s)
    Vehicle : .....
    Trim : .....
    Engine : .....
    Year : .....
    Mileage : .......
    Quote Originally Posted by Jonh View Post
    Why LED is not? I would argue, when I used NU rental car Las Vegas https://rental24h.com/usa/las-vegas-airport/nu I took the insignia of 2015, with LED lamps, they shine well, I don’t know What is the problem to put the led on?
    Are you referring to headlights?
  1. Reversing lights
    By Bigtrev8xl in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2015, 16:44
  2. Reversing Lights - a Question for the MOT Testers
    By Woody in forum General Motoring Chat
    Last Post: 27th December 2014, 22:26
  3. Reversing lights getting brighter with engine speed/revs?
    By v6vc in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2009, 08:50
  4. Reversing Lights...which Wire?
    By bennyk in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2007, 13:20
  5. reversing lights
    By ed taylor in forum General Chat
    Last Post: 22nd July 2006, 15:48
https:www.vectra-c.comforumshowthread.php234214-insignia-reversing-lights
2018 insognia reverse light wire
