Thread: Remove front bumper AFL
    Regular Member koki's Avatar
    Aug 2018
    Macedonia
    Trim : Exclusive / Cosmo
    Engine : 2.8T
    Default Remove front bumper AFL
    How do I remove the front bumper on my Signum facelift with AFL? Is there anything different because of the headlight washers?
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Undo the screws and pop out the rivets and away it comes
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Regular Member Daywalker's Avatar
    Aug 2007
    Mitkunai k, Kaunas raj
    Vehicle : VW Jetta
    Trim : SE
    Engine : 1.4 TSii
    Year : 2017
    same as any other signum/Vectra bumper
    Aug 2013
    Arbroath, Scotland
    Trim : VXR
    Engine : 2.8T
    Quote Originally Posted by koki View Post
    If you're moving the bumper away from the car just remember to disconnect the outside temp sensor and of course the feed for the head light washers. A pretty straight forward job though
    Aug 2018
    Macedonia
    Engine : 2.8T
    Thanks I'll try tackling it on saturday
    13 Post(s)
    Remember once you've half undone the upper torx screw in the wheel arch to physically push it inwards to unlock the bumper from the wing, and then finish undoing it and remove.
    Some people make the mistake of tugging hard on the bumper to unclip from the wing. Not necessary if you follow the above procedure to unlock it.
    Aug 2018
    Macedonia
    Engine : 2.8T
    So I pull a little outwards. Then push towards the front.
    13 Post(s)
    If you've unlocked the bumper from the wing, you should be able to just pull it away from the wing.
  1. part no's for signum fog surrounds and how do u remove front bumper
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2014, 12:21
  2. How Do You Remove SRI Rear Bumper?
    By Ben H in forum Bodywork & Interior
    Last Post: 2nd April 2010, 22:42
  3. How to remove front bumper?
    By GSiFan in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2009, 22:56
