Thanks Thanks:  3
Likes Likes:  2
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Fuel Rail sensor
  1. #21
    Regular Member matthewp1633's Avatar
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Trim : 280 bhp-550Nm
    Engine : 19dth Teapot tuned
    Mileage : too many
    Where are you getting the GT20/56 is it a new unit and does the £800 include a custom Manifold?
  2. #22
    Oct 2019
    GB
    Vehicle : Vauxhall
    Trim : SRi XP1
    Engine : 1.9 CDTi 150
    Quote Originally Posted by matthewp1633 View Post
    Unit is around £400 GTB2056 reconditioned.. then manifold £150. Then theres oil lines, silicone hoses etc. Roughly around £800. Probably less
    Sent from my SM-A920F using Tapatalk
  3. #23
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Mileage : too many
    Quote Originally Posted by SamZ19DTHCDTi View Post
    Sounds good obviously you will need a remap to make use of the turbo.
    Are you going custom on the manifold or the Alfa Route or Insignia?
  4. #24
    Oct 2019
    GB
    Vehicle : Vauxhall
    Trim : SRi XP1
    Yeah I've got a good tuner. Specialises in the 1.9 CDTi.
    It's going to be the Alfa Manifold as a custom tubular manifold will be in the region of around £650/700, I cant justify that when I only paid £750 for it. I'm also looking into trying to fit a CP3 pump.
  5. #25
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Mileage : too many
    Cool the pump should be good for plenty of pressure but a GT20/56 won t get you huge numbers if that is what you are looking for but I hear it is more usuable/driveable.
    Is that the turbo from the Alfa 2.4 ?
  6. #26
    Oct 2019
    GB
    Vehicle : Vauxhall
    Trim : SRi XP1
    I've managed to source a GTB2060 with DP and water lines for £700
  7. #27
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Mileage : too many
    Happy days
  8. #28
    Jan 2016
    Finland
    Vehicle : Vectra 2.2 Direct, GTS
    Trim : GTS
    Engine : 2.2 direct
    Quote Originally Posted by FutureWorld View Post
    Hi! What do you think of fitting a 2000bar sensor to stick firmware?
    Would 5% increased fuel flow have any benefit to stock firmware with egr and dpf delete?
    0 281 002 755
    Attachment 123404
    Attachment 123405
    Hi,
    Does this 0 281 002 755 sensor really fit to Z19DTH engines? I think that the connector is a little bit different
    https://www.finjector.com/documents/...0281002755.pdf
    0281002937 is original sensor
    https://partsbos.shop/fuel-pressure-...024180130.html
  1. 1.9 Cdti common rail/fuel rail failed, ended up on a recovery truck
    By Ozyboyross in forum Engine & Drivetrain
    Last Post: 27th August 2013, 18:39
  2. Fuel Rail Pressure Sensor - another thread
    By Stevo2 in forum Engine & Drivetrain
    Last Post: 30th June 2010, 20:52
  3. Fuel Rail Pressure sensor
    By RobW in forum Engine & Drivetrain
    Last Post: 3rd December 2009, 16:55
  4. P1191 - fuel rail pressure sensor circuit low input
    By L11Marc in forum Engine & Drivetrain
    Last Post: 17th March 2009, 17:12
https:www.vectra-c.comforumshowthread.php234200-Fuel-Rail-sensor
upgrade fuel rail senor z19dth fuel pressure sensor modvectra fuel rail
