Where are you getting the GT20/56 is it a new unit and does the £800 include a custom Manifold?
Yeah I've got a good tuner. Specialises in the 1.9 CDTi.
It's going to be the Alfa Manifold as a custom tubular manifold will be in the region of around £650/700, I cant justify that when I only paid £750 for it. I'm also looking into trying to fit a CP3 pump.
Sent from my SM-A920F using Tapatalk
Cool the pump should be good for plenty of pressure but a GT20/56 won t get you huge numbers if that is what you are looking for but I hear it is more usuable/driveable.
Is that the turbo from the Alfa 2.4 ?
Happy days
Hi,
Does this 0 281 002 755 sensor really fit to Z19DTH engines? I think that the connector is a little bit different
https://www.finjector.com/documents/...0281002755.pdf
0281002937 is original sensor
https://partsbos.shop/fuel-pressure-...024180130.html
