Thread: Big brakes on my GSI?
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    Default Big brakes on my GSI?
    I just found out that my 3.2 GSi does not have the bigger brakes i think the bigger ones are 314mm, but i have the smaller SRi ones, is it because mine was one of the first GSi's? mine is 2002 reg, what parts would i need to upgrade?
    Jul 2006
    If you've got the early GSi then (I think) you'll have 302mm discs, which are stil bigger than the SRi 285mm ones. If you want to upgrade to the 314mm setup, you'll need calipers, discs and pads.
    LMF do an upgrade kit here for £319, and they'll do a discount as well. Bl00dy good deal, as the calipers alone are £200+ EACH from a dealer....
    And boy, do they make a difference!
    S.Wales, Nr Swansea
    I bought front pads and they were exact the same as the SRi 2.2 Pads mate
    yep, the LMF kit will see you to 314's with all you need..
    Regular Member Vec-trance's Avatar
    Feb 2007
    Kent
    There's a group buy on the bigger discs http://forum.vectra-c.com/showthread.php?t=18899
    S.Wales, Nr Swansea
    nice one
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Brakes
    By Si-SRI in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 10:21
  3. my brakes
    By bigron1988 in forum Handling & Braking
    Last Post: 27th November 2008, 08:03
  4. New brakes on the way...
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2007, 00:32
