Thread: Going from LED back to halogens..
    Mar 2018
    West Yorkshire
    Vehicle : Vectra c
    Trim : SRI
    Engine : 1.9CDTI 150
    Mileage : 87000
    Default Going from LED back to halogens..
    Okay so one of the led bulbs (thats not been in that long) is now faulty
    It’s dim, i pulled the bulb out and it will return to full power if you tap the led part. But will just flicker and switch off when back in the car.
    So I’ve decided to go back to halogens, ordered some OSRAM NIGHT BREAKER LASER (150% brighter)
    Will i need to disable HIDs in the opcom that i had to enable to put the leds in?
    Sent from my iPhone using Tapatalk
    Regular Member fatfred's Avatar
    Dec 2013
    Bristol
    15 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    No, they will work fine. They will be powered with the 13.8v for which they were designed, not the Vx pulsed 12 v supply which is the normal setting.
    Not sure about getting bulb out warning though but if you can't see a bulb is blown when driving maybe go to specsavers!
    Just noticed that you've posted in Detailing and car care, try posting in the right section next time, you'll get better results.
    Mar 2018
    West Yorkshire
    Vehicle : Vectra c
    Trim : SRI
    Mileage : 87000
    Using my phone, so i thought this was the forum that the led bulbs was posted on.
    And i noticed the bulb had gone so not sure where that comment came from. Cheers anyway
    Mar 2018
    West Yorkshire
    Vehicle : Vectra c
    Trim : SRI
    Mileage : 87000
    Edit:
    My bad just realised it is the forum forum. Admins feel free to move / lock
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    Enable xenon in the UEC, Will stop the power to headlights from pulsing, so it wont break led. (Will also turn of bulb check on that)
    North West - RO bonehead's Avatar
    Feb 2015
    Warrington-ish
    115 Post(s)
    2 Thread(s)
    Trim : VXR!
    Engine : Z19DTH+
    Year : 57
    Quote Originally Posted by Beanie View Post
    Quote Originally Posted by kenp View Post
    guess he already did.
    because........SIGNUM!
    Feb 2015
    Warrington-ish
    115 Post(s)
    2 Thread(s)
    Trim : VXR!
    Engine : Z19DTH+
    Year : 57
    you're going to be disappointed, I'm afraid.
    a set of HID's would have been around the same price, and a LOT better.
    Mar 2018
    West Yorkshire
    Vehicle : Vectra c
    Trim : SRI
    Mileage : 87000
    Already done, sorry this had originally been posted in the wrong forum.
    I'd been adjusting the pattern manually since the beam was too high from when i changed it for the nighteyes. heard a click when i was doing the driver side and now the beam is almost on the floor. wont adjust past a certain point... but will go up using the auto adjuster inside the car. I just have to figuire out how to make it level with the other side now lol. Gonna try unplugging that headlight. using the motor to adjust the other side and then replugging it in to see if it will work that way.
  1. I can see clearly now my halogens have gone
    By moffman in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2014, 16:34
  2. Replies: 0
    Last Post: 5th July 2012, 23:27
  3. Help, the back ligth and back door not working after using hanger
    By joacom in forum Vectra C / Signum Troubleshooting
    Last Post: 19th April 2009, 15:24
  4. Milau Trip - back seat report...WE'RE BACK!!!!
    By Duncan in forum General Chat
    Last Post: 30th September 2007, 12:53
