Likes Likes:  3
Results 1 to 10 of 13
Thread: Brake Bleeding Kit
    Sep 2018
    Herts
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Best
    Engine : 2.0T
    Default Brake Bleeding Kit
    Just bought this for £21 on ebay, seems a decent bit of kit for the price. I usually use one of those eezibleed one-way valve thingys that mean you can leave the nipple open while you pump the pedal, but although they work, they're not as "one-way" as they're supposed to be, because the pedal is never quite as firm as when a garage does the job. However, I prefer to do jobs like this myself and I dislike paying 40 odd quid to a garage for it, hence why I've now bought this Silverline tool.
  2. Likes Dog_Book liked this post
  3. #2
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    235 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Going to try one out, I need to bleed brakes on the vectra inc clutch and the clutch on the Mokka so should make it less painfull doing it on the drive. Then I just need to sort the weather
    Teapot Tuned 245/300
  4. #3
    Full Member
    Nov 2018
    Netherlands
    Vehicle : Opel Vectra
    Trim : GTS
    Engine : 2.0 Turbo (Z20NET)
    I've got one like that, other than the supplied container being too small it works great. Just keep the reservoir filled and empty the containers every once in a while and it's an easy job
  5. #4
    Sep 2018
    Herts
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Best
    Engine : 2.0T
    Yea, I did note that the bottle is quite small, but I guess if it was a lot bigger then the hinged case the kit comes in would also have to be a lot larger too.
  6. #5
    Full Member
    Nov 2018
    Netherlands
    Trim : GTS
    Quote Originally Posted by LastOne View Post
    That's probably the reason, If I had a garage I'd probably make some sort of mounting system on top of a larger container so I'd just have to connect it and pull a vacuum.
  7. #6
    12 Post(s)
    Quote Originally Posted by Dog_Book View Post
  8. Likes Dog_Book liked this post
  9. #7
    Aug 2016
    Croatia
    Trim : Cosmo
    Mileage : 100000
    I have EZ bleed kit. How does this one works exactly? Is there somekind of manual available?
  10. #8
    12 Post(s)
    Quote Originally Posted by Inovator View Post
    One quick google
  11. #9
    Aug 2016
    Croatia
    Trim : Cosmo
    Mileage : 100000
    @Big Dave. Sorry, I know how to use Gunson's EZbleed kit, I'm using it for years.
    I was wondering how Silverline tool works (language barrier)...I found similar device on YT.
  12. #10
    Oct 2013
    Derby
    235 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    It works on a vacuum
  1. Brake bleeding
    By brasch in forum Suspension, Wheels & Brakes
    Last Post: 13th August 2015, 06:55
  2. Help with brake bleeding
    By JherekC in forum Suspension, Wheels & Brakes
    Last Post: 17th May 2015, 18:05
  3. Brake bleeding
    By OLD DOG NEW TRICKS in forum Suspension, Wheels & Brakes
    Last Post: 24th July 2014, 23:19
  4. brake bleeding
    By Al 22 dti in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2012, 17:33
  5. Brake bleeding..
    By macdad in forum General Motoring Chat
    Last Post: 10th July 2012, 07:30
