Likes Likes:  3
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Starting Issue 2.0Dti
  1. #11
    Apr 2008
    West Yorkshire
    Quote Originally Posted by MadTogger View Post
    Filter was changed around 6 months ago with a service and air bled then.
    Fidnt jnow anything about about a filter in the tank, how is this accessible and is it something ECP is likely to sell or just the dealer?
    It's coarse or a set of holes in the plastic part that is in the tank
  2. #12
    May 2012
    Devon
    OK, I have finally managed to get around to attempting to sort out this problem and have started initially by changing the leak-off pipes.
    To make the job easier for access and because of the state of the intake manifold I decided to remove the whole lot for cleaning.
    Here are a few images showing my injectors and one is very wet around the outside, not sure whether this is indicative of anything or not?
    Thought that maybe I could remove the injector to check the seal but have found that it's a major job with camshaft removal necessary, don't really have time for all that.
    Is there a way to remove these injectors without camshaft removal?
    I see there is an 'o' ring on the injector shaft as well as the one under the camshaft. Has anyone got a link to the part number for these 'o' rings please.
    Also on the lower intake manifold, it is held in place with copper nuts, similar to the ones on exhaust manifolds and I cant seem to find these for sale anywhere as listings just show the upper intake manifold bolts or exhaust manifold nuts.
    Lastly, can the upper & lower intake manifold metal gaskets be reused or do they need to be renewed?
    Regards..,
    Kirk
  3. #13
    Regular Member CLUB04's Avatar
    Jan 2014
    Watford
    5 Post(s)
    Trim : SRI
    Engine : 2.2 Direct
    Mileage : 84,000
    In your first picture with the leak pipe removed, where it is wet on the cam cover, is that where you were checking fuel flow or was it like that when you went to investigate?
  4. #14
    May 2012
    Devon
    Quote Originally Posted by CLUB04 View Post
    It was wet like that before I did anything.
    I’ve put the car all back together now with new Leak-Off pipes and T pieces but couldn’t get it to start today, no fuel at all to the injectors.
    I have a manual priming pump arriving tomorrow so will try again to start the car after priming the system.
  5. #15
    Jan 2014
    Watford
    5 Post(s)
    Trim : SRI
    Engine : 2.2 Direct
    Mileage : 84,000
    I would say that was from either the diesel feed pipe or leak pipe leaking and spraying out
    There is a chance it could even be early stages of the high pressure pump going. They are run off the chain
  6. #16
    May 2012
    Devon
    Turns out to be the pump, the old girl is off to the scrappy
  7. #17
    Regular Member fatfred's Avatar
    Dec 2013
    Bristol
    15 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    Would not the troubleshooting section be more likely to hold examples of this kind of problem rather than going over things from scratch? Then you might get to the bottom of it faster than from afresh chasing things one after the other
    Guess not!
  8. #18
    May 2012
    Devon
    Quote Originally Posted by fatfred View Post
    Guess not!
    I did and posted back here to complete this thread and not leave it hanging.
  9. Likes fatfred liked this post
  1. 2.0DTi starting problems
    By Davyturner in forum Engine & Drivetrain
    Last Post: 10th February 2013, 13:29
  2. 2.0dti Not Starting
    By rossgetty in forum Engine & Drivetrain
    Last Post: 27th March 2010, 20:14
  3. 2.0dti trouble starting
    By chris1804 in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2010, 18:58
  4. 2.0DTi Starting issues.. Really need some HELP
    By Diet1985 in forum Engine & Drivetrain
    Last Post: 6th October 2009, 10:32
  5. 2.0dti non starting
    By richc in forum Engine & Drivetrain
    Last Post: 1st June 2008, 22:01
