Thread: Vectra CDTi 1.9 SRi engine issue
    Jan 2019
    UK
    Engine : 1.9 TDi
    Default Vectra CDTi 1.9 SRi engine issue
    I’ve just got a 2008 Vectra estate as above. It runs great and absolutely files down the road. However, when my fuel gets to about 1/4 tank, I feel the engine “wobble” when idling at lights, then I get loads of blue smoke from the exhaust when I accelerate
    Ant ideas? It’s only when 1/4 tank of below
    Sent from my iPhone using Tapatalk
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    DPF regen?
    Jan 2019
    UK
    Engine : 1.9 TDi
    Quote Originally Posted by justin32 View Post
    DPF regen?
    Thanks, but I’m no mechanic
    What does this mean?
    Dec 2018
    nottinghamshire
    Vehicle : vectra
    Trim : life
    Engine : 1.9cdti
    it means the diesel particulate filter (dpf) is getting clogged up by soot off the exhaust fumes and needs to regenerate , in other words the engine hasnt been allowed to get up to correct temperature because of short stop/start journeys although i dont thinks its related to whatever your problem is by the description of the problems youve described
    Sep 2014
    uk
    Vehicle : vectra C sri estate auto+ hatchback auto x 2
    Trim : est sri auto hatch design auto x 2
    Engine : 1.9 cdti 150 x 3
    Year : 08/07
    I think the first thing to establish is ,has it got a DPF ?. Is it a automatic ?
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    you might have a problem with dirt in the tank, messing with the level sensor in the tank, and you won't be the first that has seen this problem come around... it is easily taken care off though, you either add a fuel additive that cleans the mess out for you (just remember to change the fuel filter after you've emptied that tank with the cleaner additive) or you pull it from the tank and clean it by hand, it is the immediate remedy... i would do the later, than add a fuel additive that can remove the dirt from the tank, and after that replace the fuel filter...
  1. Vectra C 2.2 Z22YH Engine Dreaded P1191-5A Issue
    By chips in forum Engine & Drivetrain
    Last Post: 9th January 2023, 11:59
  2. Insignia How to sort low engine oil pressure issue - 2.0 cdti
    By kaliope in forum Insignia car chat
    Last Post: 28th December 2017, 21:48
  3. Vectra C 1.8 (05 - Pre Face lift) - Engine stuttering issue
    By etheridge in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2015, 17:48
  4. Vectra C 1.9 CDTi DPF issue???
    By lysander2k in forum Engine & Drivetrain
    Last Post: 25th July 2012, 21:33
  5. Vectra 1.9 CDTI SRI Nav Engine Misfire issue
    By Joe1 in forum Engine & Drivetrain
    Last Post: 16th September 2009, 10:14
