Results 1 to 3 of 3
Thread: 302mm Front Brake Upgrade Issue with Carriers
    Sep 2014
    Brighton
    Trim : Design
    Engine : 2.2 Direct
    Mileage : 102000
    Default 302mm Front Brake Upgrade Issue with Carriers
    I'm trying to upgrade my front brakes from standard 285mm to 302mm (as fit under my 16" wheels). When trying to fit the carrier that came with the new calipers (from breakers) is the same as the 285mm carrier, so with 302mm disc caliper will not bolt up. Is there a different carrier for the 302mm calipers??
    Regular Member Daywalker's Avatar
    Aug 2007
    Mitkunai k, Kaunas raj
    Vehicle : VW Jetta
    Trim : SE
    Engine : 1.4 TSii
    Year : 2017
    Cant help you there but most people on here upgrade to 314 calipers as it is an easy upgrade mod to do as was a standard fit on certain models.
    Sep 2018
    Herts
    17 Post(s)
    Trim : Best
    Engine : 2.0T
    Year : 2008
    There's definitely a different carrier for the 302's, otherwise, as you've found, the caliper won't fit over the disk. Looks like you've been sold 285 carriers - and possibly 285 calipers as well. As the brake disk comparison chart I compiled (under a much older username) shows, not many models had the 302s, so maybe you've been sold what is far more commonly available.
  1. 302mm Front brake set up
    By gibbon7000 in forum Suspension, Wheels & Brakes
    Last Post: 21st October 2011, 18:57
  2. 302mm Front brake kit - all you need
    By Caveman_nige in forum Parts for sale
    Last Post: 5th October 2010, 10:21
  3. 292mm caliper carriers - Rear Brake upgrade
    By parapaul in forum Parts for sale
    Last Post: 28th June 2008, 09:56
