This took some putting together i tell yer. As you can see the LC ones are the best and cheapness i had good results with the Viphid's
LC 55w with build in cancellers caused problems last time i tried a set out so steer clear of them.
HID BALLAST TESTS
Final wattage assume %85 efficient
LC 35w
3.82A
12.58V
48.05W
40.84W
Autofather 55w
3.16A
12.57V
39.76W
33.8W
Viphid 55w
4.34A
12.48V
54.16W
46.04W
No name black 50w
2.89A
12.49V
36.12W
30.70W
Car Rover X9 55w supplier info
4.77A
12.02V
57.34W
48.74W
Car Rover X9 55w
4.66A
12.24V
57.04W
48.48W
Car Rover X60 55w
4.66A
12.02V
56.013W
47.61W
Car Rover X65 65w
5.79A
12.0V
69.48W
59.06W
DLumina 55w
4.96A
12.34V
61.21W
52.03W
2nd set
5.35A
12.11V
64.79W
55.07W
LC 55w
5.32A
12.10V
64.49W
54.82W
2 x https://www.ebay.co.uk/itm/HID-XENON...frcectupt=true
1 x https://www.ebay.co.uk/itm/2-X-Car-H...53.m1438.l2649
These will give a powerfull light output and be a very bright white.
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
Exactly..I was going to put 55w in but reading up suggests that most 55w are actually only 35r a little bit more anyway?
I just want brighter lights..mine just don't seem to light up that great.a dream has 10000k in his 18 plate Mondeo and they are super bright yet 10000k on mine I literally couldn't see a thing..I would like to atleast upgrade the main beams soon
Pass but they are way brighter than my lights with 8000k in them..I've tried 10k in mine and it was impossible to drive at night..got 6k on order
I’ve ordered 6k so hopefully they’ll be ok
6000k is what you need to get a white output with a faint tint of blue.
don't bother with 55w HIDs. 35w is more than adequate. People mistake the wattage as giving out more light and think because they originally had 55w halogen bulbs, they require 55w HIDs.
It's the luminescence that's the important bit.
A standard 55 watt halogen bulb emits approx 1100 lumens.
A 35 watt 6000k HID bulb will emit approx 3200 lumens.
i.e a 35 watt HID will produce approx 3 times the amount of light that a 55 watt halogen bulb will.
EDIT some additional info about 55w vs 35w HIDs - https://www.diodedynamics.com/info/r...s.html#wattage
Cool mate .I read that before posting here..I did try 6k a couple of months ago but must of been dodgy or just crap because they wasnt very bright at all..so should I hid my main beam or getupgraded h7s? Well I think the mains are h7 anyway
Am I being stupid? Are these for the dipped beam or full beam?
