Likes Likes:  2
Thread: Rough idle - a seeming cure at last
    Regular Member Darklord's Avatar
    Apr 2018
    Northeast
    Vehicle : Vauxhall Vectra
    Trim : LS/Life
    Engine : 1.8
    Default Rough idle - a seeming cure at last
    Well I've tried a lot of things - full services, cleaning the throttle body, new coil pack, ya de da. All these things made incremental improvements, especially the coil pack, noticeably smoother running. But the idle was still Ill mannered at times, with popping and missing.
    But I can cautiously report a solution - a speculative can of "Cataclean" fuel treatment. Now I've tried other treatments previously, and I've done long journeys on full tanks of super unleaded, all to no avail. But this stuff seems finally to have got somewhere. Within about 15 min I could feel a difference, and it's remained fairly steady and consistent for over a week now, with the engine sounding even smoother than before.
    So I'm going to add another bottle next week - clearly it's dissolved something, and given the previous neglect, another dose can't do any harm.
    It's one of only 2 products that I've ever tried that actually made a noticeable improvement - the other being Millars Sport 4 diesel treatment that made a Mondeo tdci run properly.
    So for all you 1.8 owners, I recommend Cataclean - it's certainly made a difference in my car.
  2. Likes vectra ste, northpole liked this post
  3. #2
    Sep 2018
    Herts
    13 Post(s)
    Trim : Best
    Engine : 2.0T
    Quote Originally Posted by Darklord View Post
    Good to year that your problem is sorted. Super unleaded, however, isn't designed to tackle problems such as rough idling. It has two benefits; some engines with knock sensors will retard the ignition until knock occurs and then dial it back a little. Super unleaded allows these engines to retard the ignition more than 95 octane fuel. Secondly, SU often has better cleaning agents in it, as an inducement to pay the higher unit price, but to benefit from that you would need to use it for an extended period of time.
  4. #3
    Jul 2018
    Hemel Hempstead
    Vehicle : CDTi
    Trim : SRI
    I have a friend that bought an Astra with a slight misfire and EML flickering, a lot of money had been spent by previous owner to clear it, a bottle of injection cleaner on a 1/4 tank and it was fixed in about 5 miles, never had a problem after.
  5. #4
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    These symptoms can be a pointer to a MAF sensor problem accompanied by DTC P0170...where cleaning the MAF sensor filament might offer a cheap & effective cure..just posted this https://www.vectra-c.com/forum/showt...=1#post2508343 . My experience with an apparent 'dirty' MAF sensor, although I had an engine warning light & the DTC P0170 but non of the symptoms of a rough idle that you had amongst others. It might be of interest to you.
  6. #5
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    38 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    I would run another dose if it cured the problem just to make sure.
  1. 2.8T rough idle
    By donkmeister in forum Engine & Drivetrain
    Last Post: 5th December 2012, 12:07
  2. rough idle
    By ianm59 in forum Diesel Engine related
    Last Post: 17th February 2010, 17:59
  3. Rough idle on 3.2
    By rayvo-gsi in forum Engine & Drivetrain
    Last Post: 23rd February 2009, 18:04
  4. rough idle
    By ERIC in forum Engine & Drivetrain
    Last Post: 14th November 2008, 22:40
  5. Rough idle on GSI
    Last Post: 18th April 2008, 17:41
