Thanks Thanks:  2
Likes Likes:  2
Results 1 to 10 of 16
Thread: F40 Sixth Gear Grinding
    Full Member watchman's Avatar
    Apr 2009
    Leeds
    6 Post(s)
    Engine : Z28NET
    Mileage : 110000
    Default F40 Sixth Gear Grinding
    Started a few days ago, then it got stuck in reverse and 1st gear once each. Not since.
    Changed the gearbox oil for Vx oil with molyslip as well.
    It's improved but it's still grinding a bit in 6th gear, particularly when I block change from 4th.
    I'm thinking it needs looking at.
    £220 + whatever repair needs doing to the gearbox
    2007 Signum Design 2.8T
    Teapot TUNED, Powerfold mirrors, Eibachs & Bilstein B4s, Roof rails
    2006 Signum Design 2.8T with IDS+
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    259 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Had a go at resetting the cables? Apart from removing the battery it’s dead easy.
    Teapot Tuned 245/300
    Apr 2009
    Leeds
    6 Post(s)
    Engine : Z28NET
    Mileage : 110000
    Quote Originally Posted by Dog_Book View Post
    That's a good point
    I'll see if I can follow the how to tomorrow.
    The battery was easy to remove - no insulation
    Do you find the Millers Oil a lot better than standard?
    Oct 2013
    Derby
    259 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by watchman View Post
    That's a good point
    Cant say i noticed a black and white difference as a few months before i got the car it had been refreshed when the clutch was done.
    Apr 2009
    Leeds
    6 Post(s)
    Engine : Z28NET
    Mileage : 110000
    So battery out again today.
    Did reset the gear cables.
    Then found I couldn't select reverse.
    Did the reset again, then let the car roll back a bit, and was able to get into reverse phew!
    Apr 2009
    Leeds
    6 Post(s)
    Engine : Z28NET
    Mileage : 110000
    Unfortunately, 6th gear still grinds a bit.
    Can I live with this for a while, or does it need looking at urgently?
    Full Member Entharion's Avatar
    Nov 2018
    Netherlands
    Vehicle : Opel Vectra
    Trim : GTS
    Engine : 2.0 Turbo (Z20NET)
    Maybe a broken synchro?
  8. Likes watchman liked this post
  9. #8
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    38 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    the synchromesh of that gear probably has taken a beating, i would look into these options, have it repaired, find a place that refurbishes gearboxes and do a straight swap, get a 2nd hand replacement of a specialist breakers. (the last one might be the cheapest, and should come with a warranty anyway just don't remove their markings)
  10. Thanks watchman thanked for this post
  11. #9
    Apr 2009
    Leeds
    6 Post(s)
    Engine : Z28NET
    Mileage : 110000
    The gearbox repairers have quoted £845!!
    They say all 6 gears have "gone", and a bearing needs replacing.
    And parts are impossible to get hold of for an F40.
    But he has one in that he can use.
    Recon box??
    Second hand??
    Any suggestions, guidance, ideas, recommendations gratefully received
  12. #10
    Oct 2013
    Derby
    259 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Ask GPS and saabtech for quote for new box? Remind me later on txt and I’ll send you the links for saabtech down south but get the exact part number.
    Ill look on my Mokka service sheet I’m sure it was about £600 for the m32 recon job, failing that get used from a low miler
  1. grinding sometimes
    By whitey1204 in forum Handling & Braking
    Last Post: 30th August 2014, 07:40
  2. Gears grinding
    By Quicky142 in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2014, 09:46
  3. Engine RPM in sixth gear at 70 MPH?
    By GSiFan in forum Diesel Engine related
    Last Post: 5th February 2014, 14:38
  4. It must be a sixth sense !
    By FIL 4822 in forum General Chat
    Last Post: 2nd June 2013, 12:44
  5. sixth sense
    By ed taylor in forum Comedy & Humour
    Last Post: 17th November 2006, 18:50
