Thread: Rear end 'wallow' and skipping around corners, advised new rear suspension bushes
    Apr 2011
    Norfolk
    confused Rear end 'wallow' and skipping around corners, advised new rear suspension bushes
    So the car is pulling slightly to the left, and the culprit is likely to be the rear suspension bushes, diagnosed from the Hunter 4-wheel printout and local STS chap who says the bits that need adjusting to centre the alignment are adjusted as far as will go and cannot go any further.
    I did go under the car to be shown and I regret not taking photographs now whilst it was up in the air.
    I definitely need to replace the banana arms which are numbered 13 here and called UPPER CONTROL ARM and these come with new bushes fitted and are quite cheap.
    The chap was also pointing to the Part numbered 17, the LOWER CONTROL ARM but I cannot remember whether the bush was on the innermost or the outermost end of the arm, or is there a bush at both ends? This also seems to be the specific control arm where Vauxhall do not sell the bushes, they want you to buy a whole new control arm, but the bushes are to be found on ebay? Have I got that right?
    I have seen that the anti-roll bar bushes seem to be fairly easy so I shall do those at the same time I expect.
    Full Member
    Nov 2018
    Netherlands
    Vehicle : Opel Vectra
    Trim : GTS
    Engine : 2.0 Turbo (Z20NET)
    Following this, I have the same skipping issue as well as the camber that's offset very negative...
    I was going to try replacing the banana arms soon but I'm curious to see what you can find out.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    26 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    From what I remember you can get them of eBay.... but I didn't check the likes of autovax etc, they probably sell the oem bushes separate
    Sep 2014
    uk
    Vehicle : vectra C sri estate automatic
    Trim : sri auto + design auto x 2 1/2
    Engine : 1.9 cdti 150
    Year : 08/07
    The inner bushes on arms 16 and 17 do not tend to wear much if what i have seen on the 4 vectra's we own .It's the outer bushes that wear and you can buy these without buying complete arms.You will need to press them out of the arms ,if you do it on the car with the arms in situ you will need a extractor to remove as they are VERY tight in the arms or you can burn them out BUT be VERY carefull not to set fire to the electrics. If you want to make replacing the bushes ALOT easier buy blue powerflex polyurethane bushes there not cheap but you can put them in by hand and there gaurenteed for life. IF you buy new no16 banana arms buy top quality ones i bought a pair from a very well known Saab spares dealer thinking they would be good only to find that the rubber boots rotting after just over a year. My recommendation would be Febi make but saying that there was a posting not that long back about someone with problems with there Febi make arms.O and for the cost yes replace the anti roll bar bushes while your under the car it's suprising how worn they can be even though they don't look worn i've recently done 3 of ours and all were worn but diden't look like it when on the car.
    Sep 2015
    Norwich
    Vehicle : Vectra VXR
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Is it that the outer bush is twisted so under more pressure than the inner which is straight.
    Sent from my iPad using Tapatalk
    Sep 2018
    Herts
    Vehicle : Vauxhall
    Trim : Best
    Engine : 2.0T
    Although I wrote the How2 (under an old username) for replacing just the bush and not the whole arm, I don't recommend it because most of the bushes available on the net are no-name cheapo pattern parts. It's better to replace the whole arm with a brand name product.
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    221 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Keep saying but if you looked at my diary you’d seen how I did this and I should have put in it links to parts that are good quality
    Teapot Tuned 245/300
    https://www.vectra-c.com/forum/calendar.php
  1. Rear suspension bushes.
    By damadom in forum Suspension, Wheels & Brakes
    Last Post: 5th August 2015, 23:03
  2. Rear Suspension Bushes
    By Keithy in forum Suspension, Wheels & Brakes
    Last Post: 19th December 2009, 18:12
  3. Rear suspension arm bushes : How much to get done?
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2009, 23:24
  4. I'm ooking for rear suspension arms and ARB bushes?
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2009, 11:42
  5. Rear suspension bushes
    By dan1983 in forum Suspension, Wheels & Brakes
    Last Post: 11th October 2007, 08:33
