Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Rear wheel play 12 to 6 NSR. Upper control arm or Bearing ?
  1. #11
    Sep 2018
    Herts
    17 Post(s)
    Trim : Best
    Engine : 2.0T
    Quote Originally Posted by BobVectra View Post
    Ok thanks .. I can't hear any noise when I spin the wheel .. (which I presume I would if it was the bearing) .. so I'll go with the upper control arm and see what happens ... The bolt at the back of it looks like its going to be fun :-) !
    If you want confirmation that the upper arm's outer bush is worn before you go to the effort of removing the back bolt, just remove the front/outer bolt, pull the outer end of the arm away from the hub carrier and test how firm the bush is by putting a screwdriver through the hole and twisting the bush about. If it's fine it will take quite a bit of force to twist the bush, but when it does twist it will do so smoothly. If it's worn, it will either move much too easilly like it's made of jelly, or stiffly but feeling notchy rather than smooth.
  2. #12
    Sep 2014
    uk
    Vehicle : vectra C sri estate auto+ hatchback auto x 2
    Trim : est sri auto hatch design auto x 2
    Engine : 1.9 cdti 150 x 3
    Year : 08/07
    As you can't be sure of the quality of the arms it's either o/e which probably are Very expensive or replace just the bushes with powerflex at least there made in the uk and guaranteed for life.
  1. All wheel alignment and rear upper control arms
    By OzMoSiS in forum Suspension, Wheels & Brakes
    Last Post: 5th July 2015, 17:20
  2. Replies: 41
    Last Post: 6th September 2012, 20:38
  3. Rear upper control arms excessive play?
    By paul.sessions in forum Suspension, Wheels & Brakes
    Last Post: 6th April 2012, 13:15
  4. Nearside rear upper torque/reaction arm slight play in a pin/bush
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2011, 12:46
  5. play in front passengers side wheel bearing
    By wilsons 1.8sxi in forum Suspension, Wheels & Brakes
    Last Post: 22nd June 2009, 17:14
