Thanks Thanks:  5
Likes Likes:  97
Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 117
Thread: My 2004 Z20NET GTS
    Regular Member Entharion's Avatar
    Nov 2018
    Netherlands
    Vehicle : Opel Vectra
    Trim : GTS
    Engine : 2.0 Turbo (Z20NET)
    Default My 2004 Z20NET GTS
    As I'm driving around in this now 14 year old car of course I'll find some stuff that needs fixing or things I think could be improved...
    As of writing this I've had the car for about a month and I'm really enjoying the driving experience.
    So far I've managed to do the following:
    • Had the entire chain, guide and tensioner assembly replaced, good as new now!
    • Cleaned up the vectra logo on the back (letters had fallen off some time in the past)
    • Polished the headlights and turned the adjustment screw by 720 degrees
    • Cleaned and Polished exhaust tips
    • Recharged the battery because the alarm was going off constantly due to low voltage
    • Fixed the rattling seatbelt adjuster in the right hand C pillar
    • Retrofitted cigarette lighter (still need to get a new one because this one is damaged but it works)
    • Retrofitted traction control button
    • Refitted the right hand A pillar trim (one of the clips was loose)
    • Gotten some new clips for the bonnet liner that had fallen out sometime in its past
    • Replaced the battery box cover with one that actually closes properly
    • Disassembled and cleaned up cruise control stalk because it intermittently didn't work
    Still to do:
    • Do the air box mod
    • Replace front control arm bushings (ordered)
    • Replace front sway bar bushings (ordered)
    • Replace rear sway bar bushings (ordered)
    • Replace pollen filter (ordered)
    • Replace air filter (ordered)
    • Replace front wipers (ordered)
    • Replace rear wiper (ordered)
    • Replace rear banana arms
    • Get car aligned
    • Replace rear view mirror (current moves too easily)
    • Replace right hand side parcel shelf clip (currently broken off)
    • Check serpentine belt and pulleys (something makes a slight noise)
    • Check engine/gearbox mounts
    • Find source of coolant smell
    • Replace rear brake discs and pads
    • Bleed brake + clutch system
    • Paint brake calipers (still deciding on the color)
    • Fix driver seat creaking on low position (found this)
    • Find a way to keep the rear floormats from flying around
    • Retrofit gas strut in glovebox for soft-open
    • Retofit an Irmscher grill (let me know if you have one for sale)
    This list will probably grow by a mile
    And don't worry, I'll post some new pics when I make some.
  2. Thanks horaa thanked for this post
    Likes RBH, GSiFan, horaa liked this post
  3. #2
    Full Member Jon1796's Avatar
    Sep 2015
    Norwich
    25 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Had a 2l turbo 54 plate black loved it.
    belts serpentine could be tensioner bearing.
    you could align her yourself with a couple of tap measureds string and some wooden planks....a lot cheaper.
    parcel shelf clip eBay.(apart from me teal clip)
    https://nemigaparts.com/cat_spares/epc/vauxhall/z02/
  4. Thanks Entharion thanked for this post
  5. #3
    Nov 2018
    Netherlands
    Trim : GTS
    Quote Originally Posted by Jon1796 View Post
    You went up to a VXR then? How does it compare?
    Thanks, I'll check that out pretty soon, I've been wanting to replace the belt anyway, looks old.
    Alignment is expensive yeah, but I'm not confident enough to do it myself when computers can do it better :P
    I think I found it, http://www.vauxhallsuperstore.co.uk/...Right_24466028
    Nice, I'm bookmarking that, cheers
  6. #4
    Sep 2015
    Norwich
    25 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    The 19’s make the ride harder I drove quicker to work in the 2l than I do in the vxr. I love the fact you put your right foot down and smile...
    The alignment is **** easy if I can figure it out it must be.
    Sent from my iPhone using Tapatalk
    ​​​VECTRA VXR‘s BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
    TECH2WIN AND GDS2 2022 DIAGNOSTICS.
    PIN RETRIEVAL FROM SOME MODULES.
  7. #5
    Nov 2018
    Netherlands
    Trim : GTS
    A small progress update, still a lot of work to-do
    Done since my last update:
    • Did the air box mod (removed the pipe from the airbox)
    • Replaced front lower control arm bushings
    • Replaced front sway bar bushings
    • Replaced pollen filter
    • Replaced front wipers
    • Replaced rear wiper
    • Replaced rear view mirror (auto-dimming one, still need cable for it)
    • Replaced right hand side parcel shelf clip
    • Replace gas strut in glovebox for soft-open
    Still to-do:
    • Find and install auto-dimming mirror loom
    • Find and install pre-facelift light/rain sensor and loom
    • Replace rear sway bar arms
    • Replace rear lower control arm bushings
    • Bleed clutch system
    • Get car aligned
    • Replace lower engine mounts
    • Check v-belt and pulleys (it's making a churning noise)
    • Find source of coolant smell (seems to be coming from back of the block)
    • Paint brake calipers (gonna go for orange)
    • Fix rattle near parcel shelf
  8. Likes Dog_Book liked this post
  9. #6
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    334 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Pictures?
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  10. #7
    Sep 2015
    Norwich
    25 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Plasma for ribbon auto dimming mirror or......
    Gps.
  11. #8
    Sep 2015
    Norwich
    25 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    You can align the car yourself it’s really not hard and saves £100.
  12. #9
    Nov 2018
    Netherlands
    Trim : GTS
    Quote Originally Posted by Dog_Book View Post
    Pictures?
    You're right, I didn't get a lot of pictures since it's always dark whenever I get to it, I did get pics of the control arm and swaybar job
    Before
    After
  13. #10
    Nov 2018
    Netherlands
    Trim : GTS
    Gps.
    Just need the auto dimming mirror cable, I did check out a Signum today that had it but I was pretty sure it wouldn't fit so I didn't bother picking it out of the roof liner :P
    I've checked some videos, but I don't even have a flat surface to work on... I do my maintenance mainly on the street.
  1. 2004 2.0 dti
    By dervb in forum Engine & Drivetrain
    Last Post: 21st July 2011, 19:38
  2. 2004 gsi
    By Lee.. in forum Cars for sale
    Last Post: 7th January 2009, 11:26
  3. 2004 1,8 which oil?
    By jamesr in forum Engine & Drivetrain
    Last Post: 31st March 2007, 09:33
  4. 2004 Sat Nav CD with TMC
    By willc01 in forum Parts for sale
    Last Post: 4th October 2006, 10:12
https:www.vectra-c.comforumshowthread.php233984-My-2004-Z20NET-GTS&goto=newpost
