Thanks Thanks:  1
Likes Likes:  3
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Brake pipe replacement
    Aug 2013
    Arbroath, Scotland
    Trim : VXR
    Engine : 2.8T
    Default Brake pipe replacement
    Ok guys, As I got an advisory for the front nearside break pipe corroding I've had a look and I'm not sure if there is an actual part number for a replacement or is it a case of copper piping and some connectors. I looked on ecat24 and there are a few pictures of brake pipes with part numbers but they don't look like the pipe that's needing replaced?
    These are the part numbers...
    2 9177113 5562225 PIPE,BRAKE,6.0 MM OD.,PLASTIC COATED,SERVO UNIT AND MASTER CYLINDER,FRONT,LHD (FOR ELECTRONIC STABILITY PROGRAM) (IDENT ZG) (NLS.- USE 13130962 55 62 246) 1
    6 13187792 5562280 PIPE,BRAKE,6.0 MM OD.,PLASTIC COATED,SERVO UNIT AND MASTER CYLINDER,FRONT,LHD (IDENT HF) 1
    7 13187793 5562281 PIPE,BRAKE,6.0 MM OD.,PLASTIC COATED,SERVO UNIT AND MASTER CYLINDER,FRONT,LHD (IDENT HG
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    222 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    As per the other thread ask the people who sell them you want the latest part supplying.
    Teapot Tuned 245/300
    https://www.vectra-c.com/forum/calendar.php
    Aug 2013
    Arbroath, Scotland
    Trim : VXR
    Engine : 2.8T
    Quote Originally Posted by Dog_Book View Post
    Would you agree with my initial post that the brake pipe is an actual part or is it something that has to be made up? I'm waiting for vx to phone me to pick up my IDS for the front so I'll bombard them with questions when I get there?
    Oct 2013
    Derby
    222 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Well since both come up as buyable parts from gps you’d think so
    Sep 2014
    uk
    Vehicle : vectra C sri estate automatic
    Trim : sri auto + design auto x 2 1/2
    Engine : 1.9 cdti 150
    Year : 08/07
    Note that the ECAT does not list alot of parts that are only for cars with steering wheel on the right hand side. Your list of brake pipes have LHD in the description. I've never bought a o/e steel brake pipe for a car or m/c i've always made them up with copper nickel pipe or had them made up with same.
    Sep 2015
    Norwich
    Vehicle : Vectra VXR
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Aug 2013
    Arbroath, Scotland
    Trim : VXR
    Engine : 2.8T
    I'm not sure that the parts listed are the same as mine as took a photo and the bends look different, don't want to buy them and find out they are not the correct ones. I know I can return them if wrong but would like to know that they are the correct ones otherwise I'm going to have to look into getting pipes made up but there ain't many places near me anymore that do that sort of thing. Need to sort out my other problems as well as they seem to be mounting up. Maybe another VXR on the scrap heap before long?
    Jan 2019
    Fife
    Trim : Exclusive
    Engine : 1.9 cdti Z19DTH
    If your in no rush pm me your reg and all check on Monday buddy
    Oct 2013
    Derby
    222 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by sinbrad View Post
    Get the RHD versions confirmed by GPS then.
    If its only brake pipes and parts of the vacuum and servo it will be a cheap fix for someone else if you get rid.
    Sep 2018
    Herts
    Vehicle : Vauxhall
    Trim : Best
    Engine : 2.0T
    PM me your reg number and I'll crank up my copy of the Electronic Parts Catalogue in the morning and see what it says is available from Vx.
  1. Brake pipe replacement
    By paulmatty in forum Suspension, Wheels & Brakes
    Last Post: 2nd February 2017, 14:50
  2. Rear brake pipe replacement - Vectra C hatchback
    Last Post: 2nd February 2017, 05:30
  3. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  4. Brake pipe replacement ns near petrol tank
    By david106 in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2012, 21:02
  5. where can i get replacement i/c pipe??
    By vectra_c_wannabe in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2010, 17:22
