Thanks Thanks:  3
Likes Likes:  61
Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 94
Thread: Matts Budget 1.9 150 SRI
  1. #51
    Sep 2018
    Herts
    15 Post(s)
    Trim : Best
    Engine : 2.0T
    Year : 2008
    Does it smoke?
  2. #52
    Regular Member matthewp1633's Avatar
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Trim : 280 bhp-550Nm
    Engine : 19dth Teapot tuned
    Year : 2008
    Mileage : too many
    Quote Originally Posted by LastOne View Post
    Does it smoke?
    At the moment without the R80 pump and injectors it doesn t smoke excessively.
    I pulled 3 of the injectors yesterday but the 4th injector would not move, so today I have a slide hammer that I have borrowed from a friend. Once I have all 4 standard injectors out I can fit the insignia ones with new sealing washers. The insignia Injectors are better for power but need mapping to obtain the extra power but the R80 pump can be just fitted but without mapping it will just provide the pressure the Ecu commands.
    Will it smoke excessively well thats a good question......
    It will definitely smoke more but Mr Teapot has advised a full power Data run in 4th gear to make fine tuning adjustments and he has said he will make adjustments if the smoke is too much. My own feelings on too much smoke are I am ok with a fair bit of smoke as my car is Sapphire Black but I don t want it too be ridiculous as it is a daily drive that often has the wife and kids in it.....
  3. #53
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Year : 2008
    Mileage : too many
    My parts list:
    Turbo and manifold and downpipe .......................£200 second hand
    Injectors......................................... .................Free second hand
    R80 pump.............................................. .........£130 second hand
    Intercooler hose kit...........................................£59 New
    80mm MAF............................................... ........£25 second hand
    4 bar MAP............................................... ..........£15 Budget new
    Plus a manifold gasket and Remap makes the whole lot less than £600 in total. I guess if you were fussy you could include the front mount I already fitted but this is still something that cost vasty less than a garage fitting a recon standard unit.
  4. #54
    Sep 2018
    Herts
    15 Post(s)
    Trim : Best
    Engine : 2.0T
    Year : 2008
    I was under the impression that any smoke, of any colour from the exhaust will be an mot fail as of may last year.
  5. #55
    Regular Member pogo's Avatar
    Feb 2006
    Growing old disgracefully!
    7 Post(s)
    Vehicle : Vauxhall
    Trim : Astra gtc vxr
    Engine : 2.0 turbo
    Great result mate and have enjoyed reading your thread so far, keel up the good work and as has been said previously the car must be properly quick, my old tuning box equipped 150 cdti was quick with a rr figure of 186 bhp!
  6. Likes matthewp1633 liked this post
  7. #56
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Year : 2008
    Mileage : too many
    Well to be fair it is a metered smoke test which is not carried out under load. As it is not under load the boost level will not reach anything like its max and therefore the fueling (which will cause the smoke) will not reach max either.
    I also have a twin tailpipe so the probe will actually only be metering 50% of what the engine produces so I expect to pass without issues.
    If it does fail I also have a very basic map that can be uploaded before the car goes for test and that will 100% get it through the emissions test so Ha!
  8. #57
    Mar 2013
    Scotland, North East
    Vehicle : Saab 9-3 (Vectra C in disguise)
    Trim : Linear Sport
    Engine : 1.9 TiD 150
    Only on diesel cars fitted with a DPF
    Anything with just a cat is fine for visible smoke. Also the door plate value is taken into account unless it's been worn away where for anything ote 2008 it's 3.0m-1, 2008 to 2014 is 1.5m-1 (though they are trying to get values from manufacturers to stop folk scratching the value off the vin plate)
    Mine blew smoke but still only registered 0.56m-1 on the smoke opacity.
    Value from twins is averaged between the 2 pipes to get the reading.
    Sent from my SM-G930F using Tapatalk
  9. Likes matthewp1633 liked this post
  10. #58
    Mar 2013
    Trim : Linear Sport
    Quote Originally Posted by matthewp1633 View Post
    Only sticking point might be the new roadside drive by test guns they are seemingly trialling, which can scan the opacity as you drive past(laser or something like that), seemingly used in other places to nab folk and stop them getting around the emissions testing as easily.
    The other would be the ever expanding LEZ (low emissions zones) which in the end is how they will get anything pre eu6 diesel off the roads....
  11. #59
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Year : 2008
    Mileage : too many
    Quote Originally Posted by MrF View Post
    The ******s may get me in the end but not before I ve had lots of Fun.......lol
  12. Likes Samyam liked this post
  13. #60
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Year : 2008
    Mileage : too many
    So I went for a drive yesterday in the new and improved Vectra and to be fair it didn t disappoint. The Turbo starts to deliver at 2200 and is at full boost by 2800 and the power delivery is absolutely incredible. I am told to expect in the region of 280 bhp with 550 Nm but I need to do a Data run to confirm this but with the weather so bad its impossible to use the full power.
    I have also just noticed a split inner CV boot on the N/S/F so another reason not to go flat out.
    Can the driveshaft be split fron the extension shaft on the nearside?
  1. Matts
    By nikroc in forum Styling
    Last Post: 10th November 2014, 14:03
  2. Custom Car Matts
    By John55wd in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2012, 21:00
  3. car matts
    By bigron1988 in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2008, 16:45
  4. Taylored Matts
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2008, 19:13
  5. floor matts
    By yorkshireborn in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2006, 15:23
