Results 1 to 10 of 16
Thread: 06 Vectra 1.8 design
    Dec 2018
    Swadlincote
    Engine : 1.8
    Year : 06
    Default 06 Vectra 1.8 design
    Hi there . I got a 06 Vectra design and having heater problem. All speeds work and direction where to blow air but only seems to be blowing cold.
    Now I bought a thermal fuse like most of the threads say but my Vectra does not have this design of heater , even phoned Vauxhall and they checked car and confirmed this
    It been like it since I got car but I have also replaced radiator due to leak and still same , all pipes are getting hot as well could there be a block in heater in dash or anything else . Any help would be great
    Regular Member Jon1796's Avatar
    Sep 2015
    Norwich
    27 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    What about the motor or motor arms....
    http://ecat24.com/opel/catalog/part/...19/3979/40563/
    Sep 2018
    Glasgow
    I’d be inclined to give it a good bleed
    Sent from my iPhone using Tapatalk
    Regular Member Daywalker's Avatar
    Aug 2007
    Mitkunai k, Kaunas raj
    Vehicle : VW Jetta
    Trim : SE
    Engine : 1.4 TSii
    Year : 2017
    Airlock or could be thermostat
    Jul 2018
    Hemel Hempstead
    Vehicle : Signum CDTi
    If the radiator was leaking, someone might have used Rad Weld, this can block heater cores.
    Sep 2018
    Herts
    17 Post(s)
    Trim : Best
    Engine : 2.0T
    Does the water temperature gauge show a normal reading?
    Dec 2018
    Swadlincote
    Engine : 1.8
    Year : 06
    Quote Originally Posted by LastOne View Post
    Yes this goes up to normal but can fluctuate
    Dec 2018
    Swadlincote
    Engine : 1.8
    Year : 06
    ( arms on side behind left side panel in footwell) i watched these move as when moving the speed and position settings but moved slowly
    Dec 2018
    Swadlincote
    Engine : 1.8
    Year : 06
    Someone did say to me put hosepipe on the to pipes coming out the bulkhead in engine bay just to see if there's crap in there , is this good idea
    Jan 2008
    117 Post(s)
    Vehicle : .....
    Trim : .....
    Engine : .....
    Year : .....
    Mileage : .......
    I'd replace the thermostat.
    Now as it's the vvt engine, don't waste your money on a pattern part.
    Buy an oem WAHLER part.
    This is the only way to go when replacing these on the vvt.
  1. Here's my vectra design 120
    By Vectra kris in forum Vehicle Diaries
    Last Post: 11th June 2015, 20:16
  2. vectra design
    By Swedge in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2012, 16:37
  3. My Vectra Design
    By Redviper in forum Quick Photo Album
    Last Post: 27th October 2009, 17:13
  4. Our New Vectra Design
    By Ross-SRi in forum Quick Photo Album
    Last Post: 16th October 2009, 07:06
  5. Vectra Design 1.8
    By Tim2100 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2007, 03:51
