Thread: Astra VXR discs
    Regular Member matthewp1633's Avatar
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Trim : 280 bhp-550Nm
    Engine : 19dth Teapot tuned
    Mileage : too many
    Default Astra VXR discs
    Hi Iam being offered a set of 320mm astra VXR discs will they fit my vectra sri 1.9cdti 16 valve?
    Aug 2016
    Croatia
    Trim : Cosmo
    Mileage : 100000
    AFAIK not.
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    No yours has 285 discs
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Mileage : too many
    Sorry I should have been clearer I have been offered the front calipers and carriers so I can upgrade the brakes. Obviously I will purchase new discs and pads and I have 19 inch rondals but I thought the normal vectra brake upgrade was 315 but the guy says the astra VXR discs are 320 so I am just checking they will fit my vectra?
    Regular Member bigdov's Avatar
    Oct 2016
    Fife
    11 Post(s)
    Trim : Design V6
    Engine : z28net(l)
    calipers won't fit, the bolt spacing on the hub are different so you'd need adapters made up, same reason why the 345mm calipers albeit do get used on the astras, but its not as common as for the cost a set of ksports or at the lower budget end megane brembos are a more viable option.
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Mileage : too many
    Hi Bigdov thank you for saving me from wasting money
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    Normal Vectra upgrade is either 302mm or 314mm
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by john_k_sri View Post
    And 345
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Mileage : too many
    Hi Guys yes I have done my research on the forum and I was aware of the normal upgrade route of 314 or 302 and I will be on the look out for those. I was offered the VXR ones and I just wanted to check if they were a viable alternative but it is clear they are not.
  1. Is it Astra h or Astra j gearstick that fits vec c
    By jon1.9cdti in forum Bodywork & Interior
    Last Post: 10th May 2012, 07:28
  2. Replies: 1
    Last Post: 21st October 2008, 15:11
  3. Can you fit 314mm discs to replace discs on back wheels of a GSi 3.2???
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 21:10
  4. Fitted for 314mm discs but fitted with 304mm discs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 13:19
  5. astra vxr discs and calipers
    By fixerman in forum Handling & Braking
    Last Post: 28th December 2007, 15:27
