Results 1 to 3 of 3
Thread: Barometric sensor
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Trim : Club
    Engine : Y20DTH
    Mileage : 79k
    Default Barometric sensor
    Yesterday I got the Spanner light on while just driving a steady 20mph, stayed on for about 3 minutes and it was in limp mode, I dropped a gear to max the revs out, well as much as limp mode let’s you, then all of a sudden it kicked back into life and spanner light went out,
    fault codes were P0105 & P1105, MAP and BAP sensors,
    cleared codes and P1105 came back under pending codes, Cleared it again and it was fine,
    Today I decided to disconnect the Barometric sensor to see what would happen,
    the car started just fine, I expected the spanner light to come on which it did, but the car drives better with it disconnected, the boost 2k onwards is a lot better and pulls brilliant,
    so can these barometric sensors give incorrect readings to the ecu resulting is poor performance but without bringing the spanner light on?
    Because the car drives absolutely brilliantly with it disconnected
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    you could try and clean it with an electrical cleaner, with your car being the y20dth it will always get covered in oil so try to clean it, if you don't have any electrical cleaner at hand, some warm soapy water in a spray bottle will do the trick as long as you rinse and dry it afterwards.
    and yes it will give false readings if it is dirty.
    Oct 2009
    Sandwell
    Trim : Club
    Engine : Y20DTH
    Mileage : 79k
    you on about the Barometric sensor or the MAP sensor? my problems with the BAP sensor by the airbox just behind the MAF, i used electrical cleaner on it though but it seems to have killed the sensor but i cant see why electrical cleaner would do that, its giving code P1105-03 (low voltage) and wont clear the code , so the sensor defo seems dead, it must of been on its way out anyway by the looks of it, only £10 on ebay for a used one so ill try that,
  1. Signum 2.2DTI Barometric Pressure Sensor
    By F4af100uk in forum Engine & Drivetrain
    Last Post: 20th April 2013, 20:25
  2. Barometric Pressure Sensor - P0105
    By Chris B in forum Engine & Drivetrain
    Last Post: 5th June 2012, 18:50
  3. Where is a barometric sensor 2.2dti?
    By riauba in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2011, 08:57
  4. barometric peasure sensor any1 know were it is??
    By barrymanalow87 in forum Diesel Engine related
    Last Post: 13th March 2010, 00:15
