Have you plugged in a code reader to see if there are any codes?
Currently at a mech garage. They've discovered a broken pipe which was throwing away oil. 👇
Yes mechanical on v6.
Well, the steering soften a bit after the pipes were repaired. It still very stiff when the car is stationary as you need to apply considerable force to turn the wheel but soften while driving. Verdict is the pump is shot! Looking for new one to buy and fix.
Why don't you try to find a good secondhand replacement unit? Now with you being in Nigeria it leaves you to look at countries around you to get it from a reputable car salvage place (we call them car-breakers or scrappies in the UK) longstory short to buy a new one will be expensive, it will be cheaper to get a refurbished pump but i don't know if the market in Nigeria actually does refurbished items... they should.
