Thread: Intermittent vibrations on throttle
    Sep 2018
    Lisbon
    Trim : Caravan
    Engine : Y30dt
    Default Intermittent vibrations on throttle
    Hi again guys.
    In the last couple of days ,my caravan started to vibrate on load,between 80 and 110km/h when becomes more strong to feel in the pedals and on the steering wheel.
    The gearbox mount is dead, will be replaced ,but i need a opinion ,if only the mount worn could do such vibrations.
    Its intermittent.sometimes its There,sometimes doesnt.if i pass the 120km mark, becomes less strong but still feel a vibration on the floor of the car.could be a bad CV joint?
    I need ideas!!
    Thanks !!!have a good week!
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    in my experience when the gearbox mount is gone you usually feel it under load only, that said it could be a drive axle causing the vibrations also and if t is that it would be because of the mount not keeping the gearbox in place.... the longest drive shaft is the one that feels carries the vibrations to the steeringwheel.
    Regular Member matthewp1633's Avatar
    Oct 2016
    PLYMOUTH
    Vehicle : vectra
    Trim : 280 bhp-550Nm
    Engine : 19dth Teapot tuned
    Mileage : too many
    Is the DMF a possible cause?
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    it could be but you would hear and feel that when the car is not under load and you press the clutch pedal.
    Sep 2018
    Lisbon
    Trim : Caravan
    Engine : Y30dt
    Dmf was changed 1 month ago.it was when we saw the mount loosing oil.
    So,maybe its just the mount and nothing else? Never tought that only the mount could lead to such vibrations and unconfort like this
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    Yes it could be just the mount
    Sep 2018
    Lisbon
    Trim : Caravan
    Engine : Y30dt
    Ok! I will change the mount and then i say the differences between before and after
  1. vibrations
    By tiimi in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2012, 17:55
  2. intermittent throttle response
    By helisurf in forum Engine & Drivetrain
    Last Post: 21st December 2011, 22:06
  3. Bad vibrations
    By tony tyre 1 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th November 2011, 07:25
  4. Vibrations?
    By Exclusive BV in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2011, 15:40
  5. Vibrations!!
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2008, 11:39
