Likes Likes:  1
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: canbus faults. ABS, ECM, power stearing all loosing canbus
  1. #11
    Jul 2014
    Bangalore
    Vehicle : Vectra C Saloon
    Trim : Saloon
    Engine : X22SE
    Year : 2002
    yes, that i learnt by chance. during one particular drive, i lost power steering and speed dials and the DIS display was all "F". For some reason i had to use horn and suddenly everything came back online.
    I identified the wires which are creating the problem. one pair is coming from engine side and the second is coming from the CIM side. if i use a jumper to patch them directly engine and RPM dial is okay but the speed and ABS remains offline.
  2. #12
    Regular Member Jon1796's Avatar
    Sep 2015
    Norwich
    27 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Have you got a wiring diagram.
    yes as you patched them together they’d work like that but everything in engine bay goes through abs that’s why no speed or abs.
    id track the canbus line (+ -)from to abs cim and try and find where it’s failing.
  3. #13
    Jul 2014
    Bangalore
    Trim : Saloon
    Engine : X22SE
    Year : 2002
    I do not have wiring diagram. it would be great if someone can share it. i will track the canbus line from and to CIM. most like it is near the ABS connector since pressing it fixing the problem for a while.
  4. #14
    Sep 2015
    Norwich
    27 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    I did post some for some one else if you read it.
    http://www.vxronline.co.uk/forum/sho...-diagram/page2
  5. #15
    Jul 2014
    Bangalore
    Trim : Saloon
    Engine : X22SE
    Year : 2002
    Thanks Jon!!
  6. #16
    Jul 2014
    Bangalore
    Trim : Saloon
    Engine : X22SE
    Year : 2002
    Here is a recording of canbus recovering after the use of horn.. i dont understand what happens when horn is pressed.
    https://youtu.be/v4V90NvQGQY
  7. #17
    Sep 2015
    Norwich
    27 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Have you checked engine bay earth’s.
    Sent from my iPhone using Tapatalk
  1. half canbus to full canbus
    By MORGIE8153 in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2017, 22:42
  2. intermittent canbus faults any ideas
    By phillcdti in forum Electrical & ICE (including SatNav)
    Last Post: 31st December 2014, 23:57
  3. Full Canbus - Half Canbus. Whats the difference?
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2013, 09:02
  4. 2004 Signum 2.0 DTI loosing power and showing faults
    By 1ctchris in forum Vectra C / Signum Troubleshooting
    Last Post: 1st September 2010, 12:41
  5. Whats the difference between a canbus car and a half canbus car
    By chuckleuk in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2010, 21:07
abs canbus faulty
Vauxhall Vectr a ABS can bus system
