Likes Likes:  1
Results 1 to 10 of 17
Thread: canbus faults. ABS, ECM, power stearing all loosing canbus
    Jul 2014
    Bangalore
    Vehicle : Vectra C Saloon
    Trim : Saloon
    Engine : X22SE
    Year : 2002
    Default canbus faults. ABS, ECM, power stearing all loosing canbus
    Hello All,
    For quite some time i am facing issues with my Vectra c Z22SE.
    sometimes while driving or sometimes after a drive the power steering, battery lights and abs lights come up.
    Here is a recording of it.
    https://youtu.be/Q1NkhuFpbjg
    Identifier: 0x0501
    VIN: W0L0ZCF6931080250
    Hardware number:12563556
    Motor type: Z22SE
    Part Number:12583487
    Software version number: 00BFF56B
    Programming Date: 20030406
    Hardware key number: S001007222
    System description: MOTOR0100
    Type approval number: G03004
    Alpha code: TY
    Hardware manufacturer system name: MOTOROLA
    Software version: 41106
    ECU variant coding: 0x00003800
    Total number of fault codes: 1
    U2108 - CAN-Bus no Communication with ABS/TC
    (00) - Present
    similar codes are present in other modules too.
    When i tap the ABS plug or use horn couple of time things restore for while. This has become a nagging problem and sometimes the car won't start unless I tap the ABS plug.
    Any help on this would be appreciated.
    Regards
    Kishore
    Regular Member Daywalker's Avatar
    Aug 2007
    Virbaliskiu km, Kaunas raj
    Vehicle : Volvo V50
    Trim : SE Lux
    Engine : 1.6 Drive
    Year : 2011
    Quote Originally Posted by krishna View Post
    Regards
    Kishore
    In that bit is your answer you need to take the ABS plug off and clean the contacts with cleaner and then hopefully your problem will be solved
    VIP-Member Jon1796's Avatar
    Sep 2015
    Norwich
    Vehicle : Vectra VXR
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 70,500
    Didn’t the early ones have bad connections or broken wires on abs plug ???
    Jul 2014
    Bangalore
    Trim : Saloon
    Engine : X22SE
    Year : 2002
    Quote Originally Posted by Daywalker View Post
    I did clean the connector and did all that, still the problem persists.
    Jul 2014
    Bangalore
    Trim : Saloon
    Engine : X22SE
    Year : 2002
    Quote Originally Posted by Jon1796 View Post
    Is it? What is solution? replace the whole wiring loom? i was thinking of cutting off the connector with few inches of wire and use connector from a donor car. any suggestions or advice on this?
    Regards
    Kishore
    Apr 2008
    West Yorkshire
    I'd be more inclined to clean the connections first (using electrical switch cleaner, not WD40) as it's a lot quicker and easier to do.
  7. Likes tolga464 liked this post
  8. #7
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    30 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Quote Originally Posted by NickT View Post
    WD40 is just the brand name nowadays, they have silicone spray, electrical contact cleaner, chain lubricant, copperspray etc etc etc all sold under the same brand name WD40.
  9. #8
    Sep 2015
    Norwich
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 70,500
    V replaced by chopping off and rewiring but a pain of a job in the space.
    You can undo the back cover of abs plug carefully try to find faulty wire and fix that rather than the whole plug !!!
    But what does confuse me is, you used horn a few times and it worked again.
  10. #9
    Apr 2008
    West Yorkshire
    Quote Originally Posted by northpole View Post
    If you mention "WD40", then generally people will refer to the Water Displacement lubricant. I appreciate it's a brand name, so I emphasised an electrical switch cleaner for the task in hand.
  11. #10
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    235 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    I can also vouch that wd40 contact cleaner is a useful as a vxr owner that uses facebook in a episode of university challenge so have now binned it and acquired some RS electrical contact cleaner as its the real thing.
    Teapot Tuned 245/300
  1. half canbus to full canbus
    By MORGIE8153 in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2017, 22:42
  2. intermittent canbus faults any ideas
    By phillcdti in forum Electrical & ICE (including SatNav)
    Last Post: 31st December 2014, 23:57
  3. Full Canbus - Half Canbus. Whats the difference?
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2013, 09:02
  4. 2004 Signum 2.0 DTI loosing power and showing faults
    By 1ctchris in forum Vectra C / Signum Troubleshooting
    Last Post: 1st September 2010, 12:41
  5. Whats the difference between a canbus car and a half canbus car
    By chuckleuk in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2010, 21:07
