Thanks Thanks:  1
Results 1 to 10 of 30
Thread: Vectra 2008 pulls to left.
    Regular Member Alleway's Avatar
    Dec 2018
    York
    Vehicle : Vectra facelift 2008
    Trim : Facelift cdti
    Engine : 1.9cdti 150bhp
    Default Vectra 2008 pulls to left.
    Hi, I have a 2008 vectra c 1.9cdti I have just installed all brand new coil overs all round and all new rear drop links rear arms ect . Ever since the steering wheel turns to the left when driving straight apparently my tracking is fine the garage says anyhelp? Thanks
    Dec 2018
    York
    Default Ps
    Ps wheels and tyres are also brand new all round
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    30 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    post up the tracking results people with more experience can tell you if it is fine from that.
    Dec 2018
    York
    I didnít get a copy of the results, I will go back to the garage tomorrow and ask for a copy . Thanks
    VIP-Member Jon1796's Avatar
    Sep 2015
    Norwich
    Vehicle : Vectra VXR
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 70,500
    Are these coil overs preset or adjustable??
    also camber/if rear camber out one side will cause front pull....l/r
    Dec 2018
    York
    They are all adjustable. Thanks
    Sep 2015
    Norwich
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 70,500
    Check your rear lower arms if you’ve got the adjustment bolts in middle, if you have, for minimum camber they should be alternate cam up cam down, if you adjust you’ll have retrack rear axle. (Easy to do yourself instead off paying someone else to do it!!!!!)
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    22 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    You should get a print out of the tracking before and after its been tracked...at least I have always done. Ask them to check it again..Was it ok before the work?..did you do it yourself?..if you did maybe recheck it. If not ,take it back...
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    If the tracking is indeed fine, then try swapping the front wheels from one side to the other.
    I had exactly the same issue a few years back, and for some reason swapping the front wheels sorted the issue.
    However, worth noting that you can only do that if your tyres aren't directional. If that's the case, I'd try swapping the rears to the front.
    Apr 2008
    West Yorkshire
    I'll assume you've torqued up any bushing bolts with the cat on the ground too
  1. Vectra C 2008 Left rear view dimming socket problem
    By nyilkin in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2011, 16:26
  2. Car pulls to the left
    By ScottR in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 10:15
  3. Car pulls to left...never guess what dealer said!!
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2008, 11:59
  4. can anyone help? car pulls to the left
    By kev bux in forum Handling & Braking
    Last Post: 30th July 2007, 12:37
